fb wagon badge location
Hi I'm new here ....Can anyone help with measurements or a template of where the SPECIAL badges and stars are fitted to the front guards?
Thanks john
Thanks john
Re: fb wagon badge location
Hey John,
Welcome to the forum. I will see if I can get some measurements off my FB sedan tomorrow, unless someone else jumps in before me with the info.
thank you Stephen , that would be great ,no hurry mate
Here you go John
Height of Special badge as shown from guard ridge to underside of centre bar.
Photo. All measurements in mm.
- IMG_4872.jpeg (579.12 KiB) Viewed 12025 times
From guard edge (where drivers door edge is) to vertical bar of first star is 415mm.
- IMG_4873.jpeg (1.94 MiB) Viewed 12023 times
From centre vertical bar of fist star to same of middle is 105. Same (105) from centre of middle star to third star (closest to headlight.
- IMG_4874.jpeg (1.87 MiB) Viewed 12023 times
From third star vertical bar to edge of centre bar (goes thro word Special) is 77mm
- IMG_4875.jpeg (1.81 MiB) Viewed 12023 times
Hope that helps John. That is how the car left the factory. Passenger side should be the same but who knows quality control may not have been a thing back in 1960?
thanks so much Stephen ,very much appreciated
no worries ,will do next week
Hi Stephen, now im think Im getting very old ......tried to click and drag a photo of my wagon and could not do it ...not sure what the trick is to put photos on this forum ???
Yes can be a bit tricky. Some folk on here use the tap a talk app thingy to post pictures, apparently that makes it easy?
When your on the screen to reply to a post, towards the bottom of the page there are three buttons (save draft, preview, submit), below that there is “attachments”. That is where you can upload a pic from your photo album.
Then “add files”
Hopefully this helps. Note there is a file size limit, think it is 2mb per file.
Then “add files”
- IMG_0073.jpeg (884.16 KiB) Viewed 11705 times
When you hit add files it comes up with this.
- IMG_0074.jpeg (1.15 MiB) Viewed 11704 times
