Fuel sender float
Fuel sender float
Post by 138 »
Investigating the "always empty" fuel problem I found that the float has come off the arm and it's still in the tank . Besides pinching a cork from a bottle of plonk, what can be used as a float? I was thinking of using a piece of 1" dowel (Mum's mop handle will become a little shorter). I will remove what is left of the original cork float when the tank is down to a low level .
Re: Fuel sender float
It's easiest to buy a whole new sender assembly from Rare Spares. Petrol's less dense than water, so I doubt that a dowel floats in petrol. About the only thing I could suggest is balsa, sealed well with shellac. Or the polyurethane spray buoyancy/gap-filler, sprayed into a toilet roll tube.
Just a thought.
Original ones seem to be cork, I had a NOS one in a box in EKMart and a rat or mouse ate the end out of the box and half the float :evil:
A brass float would work, although you would need to drill a hole and solder a small diameter copper tube through the middle to fiddle it up.
https://www.ebay.com.au/itm/33371628596 ... p_homepage
Or you could get some copper sheet and make your own? Alternatively try gauge works https://www.gaugeworks.com.au/
ardiesse wrote: Fri Nov 22, 2024 9:19 am It's easiest to buy a whole new sender assembly from Rare Spares. Petrol's less dense than water, so I doubt that a dowel floats in petrol. About the only thing I could suggest is balsa, sealed well with shellac. Or the polyurethane spray buoyancy/gap-filler, sprayed into a toilet roll tube.
Fuel is around 740 kg/m3, so for some typical dried Aussie timbers:
Alpine ash: 650 kg/m3 (floats)
White cypress: 700 kg/m3 (floats... just)
Jarrah: 820 kg/m3 (sinks)
Sydney blue gum: 840 kg/m3 (sinks)
Blackbutt: 900 kg/m3 (sinks)
Brushbox: 900 kg/m3 (sinks)
Radiata pine: 545 kg/m3 (floats)
Balsa: 120-220 kg/m3 (floats)
That foam filler idea is clever.
Harv wrote: Fri Nov 22, 2024 11:21 am
I have a sneaking suspicion the petrol would eat that stuff .......
Blacky wrote: Fri Nov 22, 2024 11:34 am
Hard to tell. The polyurethanes are normally fairly impervious to petrol, though other data shows they are not. I've got a can of Bostick foam here (for a project that I was going to bodgy, then my conscience got the better of me :oops: ). It reckons that new foam can be dissolved with acetone, but old foam only by mechanical means.
