Errol62 wrote: Fri Aug 09, 2024 9:53 am
The colour difference thing is similar to what I experienced when I painted my uterus, only Wedgewood blue. Out in the sun it looked a lot brighter.
Yeah mine is the same, looks like 2 different cars in some photos
Got stuck into the front end today , removed the bottom panel to straighten out year of being punished with a jack. While I was at it welded in some 100x8 flat so it has a good jack point for the next 60 years..
Do any of you fella's know if anyone does the the mounting bolts and crush tubes new ? I can go to the bolt shop but the old crush tunes are pretty worn so I'm not sure what the od should be ?
Hi all
I'm hoping for some guidance. I'm putting the hr front end back together and the rare spares Ball joint doesn't sit snugg in the upper control arm like the original? All the bolt holes line up though. Are the bolts enough to align the ball joint or is something amiss here ?
Sneezy1211 wrote: Sat Aug 10, 2024 4:37 pm
