FB ute
Re: FB ute
Hhhmmmm, this doesn’t seem right……
briby
Re: FB ute
Post by briby »
"Hhhmmmm, this doesn’t seem right……"
Doesn't look good either :roll:
FB Restomod V8 Sedan
Re: FB ute
Looks worse with all the soot and crud removed ImageImageImage
Out she comes
Just like Meccano Image
Re: FB ute
I’m not surprised, although one must ask themselves where the missing piece is ?
Do you have enough bore material to go oversize ?
Re: FB ute
Is that a chunk OT of the piston top edge?
Re: FB ute
Errol62 wrote: Sat Jul 06, 2024 4:36 pm Is that a chunk OT of the piston top edge?
Merely a flesh wound…
Re: FB ute
Found the problem, the top ring has decided to go on holidays ImageImageImage
The hole in the piston may or may not explain why she was puking out oil at a prodigious rate for the last hour of her life …..
Some of it decided to hang around in the oil ring Image
Re: FB ute
Bore is not too horrible so just chuck a set of rings on this piston and send it ImageImage
…… or maybe it’s time for a new oneImage
This block is cactus anyway, has cracks between the head bolt holes and the water jacket - is +.040” so won’t clean up at 60 so in the bin it goes.
Will reuse head, oil pump and some bolt ons but that’s about it
Re: FB ute
Oh dearie me! You've managed to get by on 5 1/2 cylinders for a good many miles. Soldier on!
Re: FB ute
Big ends are .030” so crank may be a bin job as well …. Will have a look inside the oil pump tomorrow and see if it can go around again
Re: FB ute
Hmmmm …. That engine is not looking good :(
Re: FB ute
EK Mart OR Blacky's house of dead FB/EKs :think: :lol:
Re: FB ute
Mick wrote: Sat Jul 06, 2024 10:14 pm EK Mart OR Blacky's house of dead FB/EKs :think: :lol:
You are right :esad: 6 of them at the moment and not one of them goes ..........
Re: FB ute
I have a nice rotating shortie if you need it. Harv got the lifters out of it. Get the thing out of my sight…
Re: FB ute
It is even FB era correct
