In tank fuel pump
In tank fuel pump
Hey just wondering if anyone has done an electric in tank fuel pump in a standard tank? (Carbureted)All the ones I can find say minimum tank depth of 7” and the standard tank is lucky to be 6”
Re: In tank fuel pump
I fitted the holley sniper retro fit in tank pump to my oem fb sedan tank. Initially It did just touch the bottom of the tank and I had to trim the line between the pump and out let a little which lifted the pump from the bottom of the tank, stopped all the vibration noise and works well and whisper quiet. It is currently shorter than what holley say it can go too, no problem.
Pro. no welding required
Con. no swirl pot but, can buy pump filter sponge that acts like a swirl pot.
Also, I think the ve commodore pump can compress short enough to fit in. Blacky has done this.
If i were to do it again I'd just get the weld in ve commodore kit as they have a swirl pot. In saying that I haven't had issues with surging at low fuel levels.
I'd say about the same price after all is done.
Not sure efi pumps are good for carbys though
Be mindful some systems are dead head some need a return fuel line.
- Screenshot_20231105_171508_Gallery.jpg (422.09 KiB) Viewed 13708 times
FB-Special
Big block 161
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Big block 161
Holley sniper EFI.
Excellent mate that what I was looking at.. the Holley ones do a carburettor pump with 6psi and no return line
thanks for the info..
thanks for the info..Sent from my iPhone using Tapatalk
Ok one more job done .. just need engine to feed now
I
Regulator?
It’s internally regulated at 6psi and then I have a magnafuel reg on the engine to drop it to 4psi
Nice work Gledge I'm also going to have to do this for the wagon
It is a bit of a drama as the pump is supposed to have 7 1/4” minimum depth and the sedan tank is only 6 1/2 so modifications are required to make it work
Did you get the pump from VPM Gledge I think the one Blacky did for the Rattler you can set the height, I'm sure he will mention it.
But like I said good work mate.
It’s a Holley pump kit that you set the height on but needs to be higher than recommended but not a big deal really.. I forgot to take pictures of it before I installed it
other than that I pretty simple install
other than that I pretty simple installSent from my iPhone using Tapatalk
Cheers, when are you likely to be up and running mate?
Hopefully a couple of weeks… just doing rings and bearings and roller cam..
