Red Rattler Revamp
Re: Red Rattler Revamp
Bit more progress today in between other jobs , battery cable run, had to knock up a heat shield of course I nearly had it finished then ballsed it up Image - at least I had a near complete template to make the replacement Image
Had to fit in here , battery and fuel line a bit close to the zorst ImageImage
Slapped a bit of rattle can black on it and then went and ran the rest of it
Then spent an hour and a half bolting the Fkn starter motor in the custom pipes don’t allow the easiest access in the world and the top bolt hole in the chinesuim CRS bellhousing wasn’t happy about having a bolt inserted so I had to modify a tap to fit in a hex socket then use a heap of extensions and run a tap through the bastard using a short ratchet from just behind the alternator to clean the hole out - then the bolt would wind in by hand from underneath and nip it up with the aforementioned 24” extensions and ratchet so then bourbons happened and work came to a crashing halt …..
Nicely run lines and wires.
Getting it done
I hate extractorsmainly because they cook the starter then make it near impossible to replace.
Cheers Harv, got some more to run tonight now - my wiper motor arrived from Pete Mallaby sometime last week , just got to work and it is on my desk Image
Blacky wrote: Mon Feb 13, 2023 8:04 am Cheers Harv, got some more to run tonight now - my wiper motor arrived from Pete Mallaby sometime last week , just got to work and it is on my desk Image
I got a similar one done by Ken Mclean - even has the same switch. They are a neat fit. See if you can snag the other end of the plug off an old Commie loom, as it makes it neater.
Mounted up the wiper motor- a near on impossible job on your own Image got a hand from me mate woody …..
That looks suspiciously like the genuine NASCO bonnet holderupperer. :lol:
Harv wrote: Fri Feb 17, 2023 7:43 am That looks suspiciously like the genuine NASCO bonnet holderupperer. :lol:
Same tree , different branch :lol:
Little bit more progress, finished off the fuel line in the boot -
And sorted out some tiny wires to the computer ready to wire the plug in to the new harness Image
Bit more today, finished off the fuel line at the front , had to fab up a bracket to brace it to the floor -
Made up some studs to mount the coil packs to the side of the donk , used stock side plate bolts and welded another bolt to them
Also wired in the reverse light switch, the starter motor and alternator wiring is all done
Nice job blacky.
