Project 2.
Re: Project 2.
Many thanks Greg.
Re: Project 2.
It's Sunday evening and an old man's thoughts turn to shiny wheels. I just hope they will fit over the discs on the front.
Re: Project 2.
Noice!
Belly760
Re: Project 2.
Post by Belly760 »
Brett027 wrote:It's Sunday evening and an old man's thoughts turn to shiny wheels. I just hope they will fit over the discs on the front.
I love them. ImageImage
FB Ute Stock
EK Ute in Pieces
melly
Re: Project 2.
Post by melly »
Veeerrry Nice Brett- you still gunna run tripple strommies on a 186?
cheers, melly
Re: Project 2.
melly wrote: Tue May 17, 2022 9:39 pm Veeerrry Nice Brett- you still gunna run tripple strommies on a 186?
cheers, melly
Yes, but only after motor is set up and running well. I will get motor tuned and settled down with WWcarb and standard dissy, then swap in electronic distributor and then once happy with that set up, change over to the tripples. I reckon its too hard trying to get all new stuff working at once, otherwise it makes it hard to diagnose issues.
Re: Project 2.
Start with what you are familiar with, but the electronic distributor, with correct coil, will eliminate a few potential issues, and give you a fuss free run in, with stronger spark. It is a bolt in swap. Just gap plugs accordingly and don’t listen to any palaver about resistors. Your standard loom supplies 12V to the matched coil, which is what it needs.
Re: Project 2.
Another job sorted. Image
Re: Project 2.
That looks like the good stuff, hoop pine marine ply, which is over $200 per sheet. Very nice, even if I am mistaken.
Re: Project 2.
Yup and stainless strips. Lift up section in front for battery access and storage. Can't wait for stuff to be sliding around in there😄
Re: Project 2.
Yeah man, cool as!
So close…..
melly
Re: Project 2.
Post by melly »
Brett027 wrote: Wed May 18, 2022 7:42 am
cheers, melly
righto makes sense,cheers Brett. tray looks great... so you havent had to modify the firewall on the ute then?
Melly
Re: Project 2.
Well Melly, that joy may be yet to come.😁 Mucking around with collapsable steering column and front engine mounts are next on the agenda.
Re: Project 2.
Very nice 😎👍
Re: Project 2.
Tray looks great Brett :thumbsup:
Remind me what discs are you running on the front, their size will determine your rims but I'm sure you know that.
