Ammo's Ute
Re: Ammo's Ute
Surely there a diff joint over there with a jig that could do that for you ???
Wrongway Roger
Re: Ammo's Ute
Post by Wrongway Roger »
There was a guy working out of his back shed that did diff mods so I will give him a call tomorrow.
May be cheaper and less hassles.
I see Clay has 3.08:1 coarse spline banjo centre for sale, unless there someone else in Wilunga selling Holden parts. :OMGGG:
Re: Ammo's Ute
Funnily enough there is another Clay near by that I bought an fb sedan from. He does dodgy paint and panel. I had someone contact me through gumtree thinking I was him. They weren’t very happy.
Rog you’re welcome to that diff if you want it. I’ve not had it in a car so pot luck. The one in my ute is a goody and the lsd one that was in my sedan is noisy.
Better you get a Borg Warner and shorten it with that big block 202 you’re running.
Belly760
Re: Ammo's Ute
Post by Belly760 »
Roger make sure you use the discount code.
FB Ute Stock
EK Ute in Pieces
Wrongway Roger
Re: Ammo's Ute
LJ diff on hold for the moment.
I have now completed the remote oil filter setup done.
Filter now near to auto trans with straight lines and space to do a filter change.
remote 3.JPG (83.74 KiB) Viewed 673 times
remote 2.JPG (67.09 KiB) Viewed 673 times
My first choice of location would have required the oil lines to bend 90 degrees. I did chase up a couple of formed rubber lines but at $30 a piece too dear for me.
Lowered the steering shaft support so it's is now clearing the sump.
Next up is the trans oil lines to the radiator and I have to move the brake pedal. Not enough room between the tunnel and the brake pedal.
In retrospect the tunnel could have been smaller.
cheers,
Re: Ammo's Ute
Looks very tidy Roger. Prolly easier to change now than the original position.
Re: Ammo's Ute
I love remote oil filters !!!
Great Job.
FbSTDwagon
Re: Ammo's Ute
Post by FbSTDwagon »
Nice looking job that one, where did you buy the remote filter housing?
Is it 1/4 NPT fittings?
Drew
Wrongway Roger
Re: Ammo's Ute
The remote filter kit is from Outlaw Speed shop in Rosewater.
The fittings are 1/2" NPT
Very happy with bracket I made, sits neatly and is bolt in.
Grabbed the oil lines from the wrecker this afternoon but some dick cut the front ones to get the radiator.
Not much left on this WB ute now.
Not sure if I have the bundy tube but I salvaged the fittings. A trip to Power Brakes on the cards.
Re: Ammo's Ute
EK283 wrote: Thu Sep 23, 2021 6:13 pmI love remote oil filters !!!
Me too :mrgreen:
Oberg remote oil filter.jpg (666.95 KiB) Viewed 630 times
Re: Ammo's Ute
Found it Roger - do you still need it ? Image
Wrongway Roger
Re: Ammo's Ute
Thanks Blacky but do not need now.
The remote kit and bracket is sorted and I routed new trans oil lines around it.
As I'm going with standard linkages for accelerator and not cable, I put the brake booster/ dual master cylinder on to ensure I had no clearance issues.
All good but I do not like the look of the brake lines I bend sometime ago, so making these again.
Re: Ammo's Ute
Old school linkages, love it Roger.
Wrongway Roger
Re: Ammo's Ute
I have made a change to reservoir as the master cylinder I purchased to fit to the Gemini booster leans too far back.
PBR - XA-XB (1).JPG (64.25 KiB) Viewed 527 times
Ok when used in the car it was designed for XA-XB so I spent sometime at the local U Pull IT wreckers and found the VT Comodore has the same spacing for the front and rear circuits.
A little trim here and there and it sit good. Just need to sort out how to hold it down as the tab with screw does not align. Also need a bracket at the front to support it.
PBR - VT.JPG (62.49 KiB) Viewed 527 times
Re: Ammo's Ute
I seem to recall there is a reservoir that will fit straight on and fix that issue Roger, just can't remember what its off ....
