Clay’s Wedgewood Blue FB Ute
Added 1 litre of oil. Showing some carbon now. Need to find a good spot to change it.
Errol62 wrote: Thu Jun 17, 2021 11:35 amAdded 1 litre of oil. Showing some carbon now. Need to find a good spot to change it.
Welcome to change it at my place on the way through.
Thanks Harv
Where are you Clay ????
Still on sunny coast Greg. Heading south next week.
Clay,
When you swing by Harv’s joint maybe you can see if he has a set of twin carbs or some other go fast gear for the trip home?
Looking good!
In the Shed wrote: Thu Jun 17, 2021 10:27 pm Clay,
Looking good!
Lets see.... red motor..... red motor.... there must be something here somewhere. Maybe under this pile of busted grey motor bits.
Clutched Type 75 Norman?
McGee injection?
Vertex magneto?
Long-runner manifold and race-prepped 350 Holley?
Cast headers?
or perhaps the gentleman would prefer something more subtle:
Blown EK.jpg (1.6 MiB) Viewed 937 times
Overflowing with bits already thanks guys. Got a set of hr commercial rear brakes. Under the car found the driver front leaf hanger to sill tie has rusted from the inside and travel has loosened up the scale, with holes showing. Easy enough repair when I get home.
Hi parts guru. See if you can bring a set of rear door bottom stainless trims for me when you come to visit😀. The two I've got are too damaged to put on. I've got feelers out in the meantime. Happy travels today😀.
Reminds me of a songImage
Nice n Shiny 😎
Back in black
Previous owner Kym told me the ute came from an area between Walpeup and Pinnaroo on the Mallee Highway. May still be able to pass through there on the way home with luck.
FJWALLY
Post by FJWALLY »
Your probably not coming this far south Clay but if you are you are welcome to use the hoist and share a lager.
Love to Rob. Will see what SA gov has to say when I'm closer to the end of the month.
