Getting paint mixed
anotherfbnewbie
Getting paint mixed
Could be a stupid question but you don't know if you don't ask.
Is it possible to get a paint shop to mix up a specific colour if you just supply the original GMH paint code?
Just wanting a couple of aerosol rattle cans for some minor touch ups.
Desert glow and sandstone beige.
Thanks
Thanks
[i][b]What could possibly go wrong?[/b][/i]
Re: Getting paint mixed
My local Lonsdale Paints Steve Turner will do it. He is a genuine Holden nut like us, and can practically recite the paint code table from memory.
Most paint shops will do it, the only issue is the colour may be different due to manufacturer pigment variations and also colour fade from the sun on the original paint.
It’s best to take the car to a paint shop with a spectrometer, they can then match the paint to the colour on the car.
anotherfbnewbie
Thanks for all the replies, will give Steve a call tomorrow.
And thanks for the gear stick Clay
- Gear Knob.jpg (2.35 MiB) Viewed 1492 times
As Tim points out the duco colours can’t be mixed from formula. Steve will probably want to match by eye. Give him a call.
When they match by eye do they have samples swatches to get it close and then finish tinting by eye? And if so, do they record so you can go back for more if you need it? Or do they literally do it from scratch?Errol62 wrote: Thu Apr 08, 2021 10:33 pm
Is a spectrometer a mobile scanner they can take out to the car outside? What size sample do they need for a reliable scan?
Apologies, haven’t ever been anywhere near the painting stage on a project.
Cheers, Andrew
Ask around local restorers and find a shop that is helpful and know their stuff. Old school use swatches and vary formula on a panel you bring in and will be able to reproduce. My local charges $50 to match as of recently.
A mate of mine sells automotive paint and he needs a bit about the size of a cigarette packet to match it with the spectrometer, it’s pretty accurate
Some spectometers are mobile. I bought some touchup paint for the HR wagon (Silver Mink) by code, and it was nowhere near the same colour as the car. Doubt it is paint fade... suspect the car was repainted in something other than Silver Mink. Took the car to the panelbeater, who ran the machine over it. Turns out to be a weird colour used on Chery Chineses 4WDs, at least in theory. The new touchup paint he blended is spot-on.
the guys at Complete Auto Paints, Westall, Melbourne, are brilliant with older paint colours. When I had the paint mixed for my FB ute,(Banff Blue) the best, unfaded sample we could find was the glovebox lid under the hinge. They eyematched to this tiny sample then as an experiment also mixed some paint from the original acrylic code, which they had. We could not tell the difference! And they don't charge any extra for this service. Cheers, Fraze
anotherfbnewbie
Steve and Jodie were very helpful but after using their spectrometer they could not identify Desert Glow and the nearest we found to Sandstone beige was Barrier Coral.Errol62 wrote: Thu Apr 08, 2021 10:33 pm
As mentioned in previous posts, i think I'm gonna have trouble as it's nitro paint which GMH originally only for six months or so.
On the FBs, but also FX FJ FE FC.
