Shed find ute
Re: Shed find ute
The blokes at Burt Brothers were discussing similar Wilwood masters with me the other day. They reckon no booster needed either, as the master puts out some incredible pressure with little pedal effort. I assume they have a small piston diameter to get the pressure, long pushrod travel to deliver the same volume to the caliper and a rejigged pedal geometry to get the same pedal travel for the increased pushrod travel.
Re: Shed find ute
Gledge on here runs no booster on his FB sedan with full house red motor.
WesternWagon
Shed find ute
Post by WesternWagon »
Bit of inspiration from the spanned day
Tidying up the last few rust repairs needs final sand a tap
Install remaining seatbelt and satin clear the dash then fit windscreen and roof lining
Member : Holden Car Club WA.
:ASRF Member
Re: Shed find ute
Nice work Gazza
Re: Shed find ute
Those bottom guard corners are not even close hey ....
Re: Shed find ute
Well done mate.
WesternWagon
Re: Shed find ute
Blacky wrote:Those bottom guard corners are not even close hey ....
Yes mate needed some massaging Image
:ASRF Member
WesternWagon
Re: Shed find ute
Agree mate, required some hammer love to fit
:ASRF Member
WesternWagon
Re: Shed find ute
Door rubbers bailey channels and freshen the 1/4 vents
Old rubbers very crusty paint work in very good nick
:ASRF Member
BS
Re: Shed find ute
Post by BS »
Looking good!
Sent from my SM-N960F using Tapatalk
WesternWagon
Re: Shed find ute
One door down, one to go
Then off for glass and roof lining
Dang those 1/4 vent rubbers are fun Image
:ASRF Member
Re: Shed find ute
Fiddly job Gazza but you won’t miss the whistle. Good to see you progressing this mate.
WesternWagon
Re: Shed find ute
Bit of a trim for the radiator, could squeezed it in but don’t want it to rub
Will blend some 1/4 plate into the subframe for the lower mounts
I love this little body saw, 1/4 hole and off you go, little linishing grinders are handy also Image
:ASRF Member
funkyscooter
Re: Shed find ute
Post by funkyscooter »
My tight arse tip with the powerfile/grinder. Buy normal belt sander belts and cut them to size with a Stanley knife. I’ve cut some as small as 10mm to get into tight spaces.
Scott
Scott
Re: Shed find ute
More on this please Gazza
