Ol' Rusty - FB/EK Sedan
Re: Ol' Rusty - FB/EK Sedan
Kudos to the young bloke , good to see he perseveres with a job like that instead of wandering off :thumbsup: :thumbsup:
funkyscooter
Post by funkyscooter »
repair 1.JPG (604.23 KiB) Viewed 1057 times
Found a bit of rust passenger side sill in the rear wheel arch. Previously repaired. Cut/ground out the old patch
Scott
funkyscooter
Made up a template with a bit of aluminum. Decided to have a crack at mig welding. Figured no one will ever see this.
Scott
I've got a paper template for this section - I can photocopy it and mail it to you.
(Only just saw your aluminium one. Offer still stands.)
funkyscooter
After a couple rounds of weld/ grind with gasless 8mm wire. Couple of blow throughs in both the sill and my patch. Not easy working in this space and getting the MIG torch in all the right places.
Scott
funkyscooter
Thanks for the offer Rob. Still on a bit of a trip down memory lane with pictures. But want to document chronologically.
Scott
funkyscooter
A few more rounds of weld/grind (after stepping away for a week). Dremmel has been my friend in here.
Scott
funkyscooter
Finally hit it with some primer. Will leave for now and tackle the other side.
Scott
funkyscooter
Okay. So not as simple as the passenger side. Noticed a few bubbles in the sill but when I attacked it with my sharpened screw driver it pretty much fell apart. Went to work with the angle grinder to check the inner sill. Looked ok under the car.
Scott
Very tidy. Yes it is a tricky spot. Do yourself a favour and get some gas.
funkyscooter
Not so great. Lots of little pin holes. Sigh. Did some reading and the outer sill ‘seems’ relatively simple to repair.
Scott
The paint was all that was holding the shape. Usually passenger side is worse.
funkyscooter
Then I got to the A pillar. Both inner and outer A pillar sections need work, as well as the subframe bracket. There is also a bit of rust in the floor around the A pillar that has been badly patch over.
Scott
It is a big job but the replacement panels help. Inner can possibly be saved? Patch from the inside and paint and protect well.
funkyscooter
After much hand wringing and read decided to fix this myself. Read somewhere on this forum with regards to welding and body work that it’s only metal, if you make a mistake, cut it out and do it again. Good advice
Ordered new inner and outer sill, inner and outer A pillar section , lower fender repair section, 6mm MIG wire, a regulator, and a D bottle of gas. In for a penny.......
Scott
