Ol' Rusty - FB/EK Sedan
funkyscooter
Re: Ol' Rusty - FB/EK Sedan
Post by funkyscooter »
01_take Notes.JPG (659.38 KiB) Viewed 1715 times
So first things first. Take notes. Don’t remember what I was on about with the vacuum stuff but the firing order is right. I think!
Electronic distributor luring in there, Stromberg carb removed.
Scott
funkyscooter
Bonnet off. Rocker cover too. Water pump was in flakey pieces. Should have drained it. Easy to get a new one. Engine only had about 10000K's on it after a reco so that was pretty lazy on my part
Scott
funkyscooter
More decay
Scott
funkyscooter
Unbolt the drive shaft, cut the exhaust (all welded), and it’s time to get the gumtree hoist into action
Scott
funkyscooter
Scott
153634 repeat 153624. Looks like the leads are right but notes are wrong.
Thanks for the pics.
funkyscooter
Errol62 wrote: Tue Nov 10, 2020 8:07 am 153634 repeat 153624. Looks like the leads are right but notes are wrong.
Ha! I don't know where I got that from then! Good start :wtf:
Scott
Also looks like its an EK that someone has tried to improve the looks of by fitting FB bits to :lol: - very common amongst EK owners :thumbsup:
Firing order: let Kedron Taylor be your guide.
https://www.youtube.com/watch?v=HQIl3Q65MOg
Great pics Scooter keep them coming mate.
62ekute
State: ACT
Post by 62ekute »
funkyscooter wrote: Tue Nov 10, 2020 8:30 am
142635 works if you count them backwards in a loop if that makes you feel better
funkyscooter
Blacky wrote: Tue Nov 10, 2020 9:56 am Also looks like its an EK that someone has tried to improve the looks of by fitting FB bits to :lol: - very common amongst EK owners :thumbsup:
The front is an FB ute, and the back is an EK. So I get the simplicity of the FB chrome work up front, including rusted out bonnet trim.
Scott
funkyscooter
Advantage of hoist. Lower car when engine won't go any higher.
Scott
funkyscooter
So plan of attack.
Repair any rust and paint under the car. I think I can do the stuff that no one will ever see.
Tidy up the body work as much as possible, remove any bog, and send her off for some staightening and a respray.
Engine rebuild, think the gearbox is fine but will get a once over as its all out.
Overhaul brakes (were pulling to the left quite badly, new wheel bearings and replace all rubbers (both mechanical and body).
New pinion seal in the diff which is leaking and has added to the fine mist of rust protection from a leak somewhere up front.
This becomes job # 1 as with the diff out its much easy for my son Cooper to get under the car and start cleaning all the gunge off things. He was doing Duke of Ed at the time and this was his "Hobby".
Scott
funkyscooter
Diff out.
Notice the OzChev sticker on the rear door. Had the car 3 years clueless and its my Dad who's looking at the car for the first time and goes "Who's OzChev"
EDIT Gaps on the back door look right - but the trims not lining up. Must remember to fix that.
Scott
