Chev EK
Re: Chev EK
WesternWagon wrote:
Keep them pics coming gets me motivated to Finnish the ute
Gazza
If you can’t be bothered to Finnish that Ute gaz you could always Denmark it. ;)
Re: Chev EK
Errol62 wrote: Sun Jan 06, 2019 1:50 pm
Gazza
I Swede what you did there :ebiggrin:
Re: Chev EK
There’s Norway this Nordic punning can continue...
Re: Chev EK
Swede.
WesternWagon
Re: Chev EK
Post by WesternWagon »
Gazza
Turnip up you blokes I don’t know what ya on about Image
Member : Holden Car Club WA.
:ASRF Member
Re: Chev EK
WesternWagon wrote: Mon Jan 07, 2019 10:52 am
Gazza, this is about countries not vegetables you Turkey :lol: - you must have been Hungary when you were reading it ?? :ebiggrin: :ebiggrin: :thumbsup:
Re: Chev EK
I like beetroot on my hamburgers !!!!!
Re: Chev EK
So as usual just no time for the car but I have done some things, last couple of days after work I have finished up my steering column change.
I originally used two Torana unis but have wondered about road shock considering the UC steering rack is solid mounted.
So after some research and head scratching I came up with this combo.
Borgeson Stainless vibration uni.
I machined up a bearing stopper, pressed that into the column, machined the steering shaft to suit the Double D uni and bearing, then slid that inside the shaft and locked it in position at the steering wheel end (circlip) I planned to cut the excess off the column tube but I figure this may protect the rubber part of the joint from heat.
Anyway a bit more done and I have also prepped 3 doors and the boot for paint. All my chrome is being done and I should have that back soon.
Re: Chev EK
That looks a lot neater than the Torrie rag joints.
Re: Chev EK
Hi guys,
Can someone tell me what the stock distance from the top edge of the dash to the steering wheel rim is please ?
regards Greg
WesternWagon
Re: Chev EK
I’ll go measure the sedan
With the DD uni I had to move the around a bit the clear the pugs and headers
:ASRF Member
Re: Chev EK
Déjà vu
Re: Chev EK
Steering wheel from dash measurement
https://r.tapatalk.com/shareLink?share_ ... are_type=t
Re: Chev EK
Thanks guys,
Bit of an update, acid dipped panels, completed in hifill all but one door and a bit of wiring !!!!!!!!
Also finished accelerator steering and brakes so vroom vroom soon !!!!
Will try and start this motor shortly !!!!
Re: Chev EK
Those panels look very nice. Mind the duco on the Stude mate.
