Timing gear set
- Craig Allardyce
- State: VIC
Timing gear set
Hi everyone, as it states I'm chasing a cast steel timing gear set from Master Engineering in Adelaide.
Not after the Speco ones on Ebay as that's what I'm having problems with.
Thanks in advance.
Thanks in advance.
Re: Timing gear set
Hi Craig,
I gather Master Eng are still out of stock? I tried to obtain one from them last year but no joy. Good luck.
Regards Stephen
Regards Stephen
Re: Timing gear set
Check out Automotive Surplus in Mitchem. When I got a set from them a while ago, I am certain they weren't Speco.
Rod
Rod
- Craig Allardyce
- State: VIC
Re: Timing gear set
G'day Stephen, I cant even find a phone number for them.In the Shed wrote:Hi Craig,
Regards Stephen
- Craig Allardyce
- State: VIC
Re: Timing gear set
Thanks Rod.yaapeet30 wrote:Check out Automotive Surplus in Mitchem. When I got a set from them a while ago, I am certain they weren't Speco.
Rod
- Contact:
Re: Timing gear set
I think the Vic Club used to also keep a few of these in their stock? Maybe PM Rosco or someone form the Vic Club?
- Craig Allardyce
- State: VIC
Re: Timing gear set
Thanks Stewart. I got onto Bill Reid via fb, just waiting on an answer as to whether I can buy one.parisian62 wrote:I think the Vic Club used to also keep a few of these in their stock? Maybe PM Rosco or someone form the Vic Club?
Re: Timing gear set
Try this Craig
http://www.masterengineering.com.au/con ... ering.html
- image.png (346.75 KiB) Viewed 2074 times
Re: Timing gear set
Yeah well - no good trying him on here , he is a moderator and hasn't logged onto the site since October last yearCraig Allardyce wrote:Thanks Stewart. I got onto Bill Reid via fb, just waiting on an answer as to whether I can buy one.parisian62 wrote:I think the Vic Club used to also keep a few of these in their stock? Maybe PM Rosco or someone form the Vic Club?
- Craig Allardyce
- State: VIC
Re: Timing gear set
Just to let everyone know Master Engineering has closed its doors. All tooling and patterns were sold off to a guy in NSW......the chase continues.
Re: Timing gear set
I use another SA local companies grey timing gear sets a bit pricey but all are doing well so far http://www.jp.com.au/Performance.html JP Engineering
cheers
Scott
cheers
Scott
- Craig Allardyce
- State: VIC
Re: Timing gear set
Thanks Scott, yes I know of them. The alloy one will be my second choice if I cant get a cast steel gear set.
fb cruisin
Re: Timing gear set
What problems did you have with the Speco one Craig, I'm interested as I have one on mine as well ?Craig Allardyce wrote:Hi everyone, as it states I'm chasing a cast steel timing gear set from Master Engineering in Adelaide.
Thanks in advance.
______________
living the dream.
living the dream.
- Craig Allardyce
- State: VIC
Re: Timing gear set
I found the helix angle on teeth too tight. Whilst it went in with the correct backlash, it wore to over 010" backlash due to poor tooth contact. The excess backlash then amounted to a noise and vibration at certain rpm and loads that was exacerbated by the billet steel material making a very metallic ringing noise.fb cruisin wrote:What problems did you have with the Speco one Craig, I'm interested as I have one on mine as well ?Craig Allardyce wrote:Hi everyone, as it states I'm chasing a cast steel timing gear set from Master Engineering in Adelaide.
Thanks in advance.
Re: Timing gear set
You sure its not the Crank Gear thats worn or cut wrong?
Cheers Theo Z............
FB/EK Car Club of QLD.
