Seagull Grey EK 2106
Craig Allardyce
Re: Seagull Grey EK 2106
Post by Craig Allardyce »
FJWALLY wrote:Well done Craig - always a magic moment when she burst into life again - can't wait for that moment myself.
I'd be keen on one of those genni sets if your looking to sell - shoot me a PM with price - I'm sure it is fair.
Thanks Wally.
Re the kits I'm not selling any, just thought about those that are having trouble finding them. I'll post details when I find the bloody receipt. Cheers.
Craig Allardyce
Devilrod wrote:Yup, pulled the driveline out. It's going slowly. Time isn't something I seem to have a lot of. It also doesn't help I keep breaking the roadster.... :roll:
You'll get there mate. There's never ever enough time.
Hope its nothing serious with the roadster.
Craig Allardyce
EK283 wrote:Top job Craig,
Must have been so hard not to paint it :) :) :) :)
Thanks Greg, yep it was hard but the good wife kept me on track..................I slipped with the engine though.
Either way we needed to leave it till after we do the Nullarbor...........would have been a waste of time and money doing it before then.
Craig Allardyce
Well done Craig, great camera work from Behind.
Can you give me your upholstery guys number? I believe his name is Paul?
bumper
State: TAS
Post by bumper »
:thumbsup: :thumbsup: :thumbsup:
wanker????
FBEKHOLDENFANS page
Craig Allardyce
Trev wrote:Well done Craig, great camera work from Behind.
Thought you'd like it. Cost me f$%& all too! He's next to the paint brush joint down your way. :lol: :lol:
.................it took me a few minutes before I twigged too.....we laughed! :ebiggrin:
It's alive!!!! Well done.
As for the roadster it's just little things, but what's the hard bit is waiting on parts..... Currently it's broken two front brake drum springs. It's got me stumped. One was fatigue but the one I replaced it with failed for no real reason.... :? :?
The joy of old cars!
Craig Allardyce
Getting close, still got interior bits and pieces to do. Went for a few squirts around the block and it looks like I've got the same clutch problem I had with the FB. May have to pull the engine. Bugger. Anyway she got a tub....first for few years!
FJWALLY
Post by FJWALLY »
Craig that looks Killer - what is the clutch issue your having?
My motor is out now also is there any clutch kit that is better than others to put in?
Craig Allardyce
G'day Wally. When at rest with the engine running theres a slight ticking/rubbing noise in the bellhousing. Usually only when the car is pointing up hill. Put the foot on the clutch and it goes. These new "upgrade clutches" have a different housing cover and have lugs that hang out on the pressure plate straps. All it takes is a little end float on the crank and the whole assembly floats backwards and rubs on the gearbox housing at any high point. My FB is at the limit with end float .008" and it was bad. Had to pull it and grind down all the high spots and dress back the edges on the pressure plate lugs. Go a standard one if you can get it.
http://www.fbekholden.com/forum/viewtop ... &start=195
Any thought of installing a 0.025" spacer gasket between block and bell housing?
Well done Craig! Good times. :thumbsup: I remember when we got the wagon on the road there was a ticking noise and we thought was coming from the clutch / gearbox. Luckily it turned out to be the fan was flexing.
vmx-mxr
Post by vmx-mxr »
The old ute is looking good Craig, and the vid was well done - especially "beer o'clock" :thumbsup:
Can I gather the aftermarket one you used is the later 8.6" diameter set
Dave Mac
FJWALLY
Post by FJWALLY »
Thanks Craig - and Dave - my motor is juts about done and should get gearbox back next week and new clutch is on the list of must do's while it's apart.
