Cutting glass
Cutting glass
Ok so as some may know I have just got a ute the bad part is I need the glass for the doors one door is a empty shell the other has sedan glass in in anyway I ask the guys at a automotive glass place (windscreen removal replace and tint) anyway they told me they can't chop or grind the side windows cause it safety glass so I asked how do guys with chop tops do it he said they must get it custom made so I'm asking the people that have done a chop top did the get the glass cut or made?
I am Watching a door on ebay I was goining to buy cause I assumed it could ground down need help asap
mmmmmmmmmmm dunno
Re: Cutting glass
I'll have a ute window but it's 4hrs away so it depends how soon u need it and what side
- Craig Allardyce
- State: VIC
Re: Cutting glass
Toey try this mob.
They maybe able to do a one off for your car.
http://www.glass4classics.com.au/produc ... new-glass/
Re: Cutting glass
I'm not in a rush just didn't want to miss the eBay door if it could be done. and now im up for both sidesCocko750 wrote:I'll have a ute window but it's 4hrs away so it depends how soon u need it and what side
the guy I deal with at work can get custom made glass done for me I'm just running a tight budget for example a slab for him if he could cut it lolCraig Allardyce wrote:Toey try this mob.
mmmmmmmmmmm dunno
Re: Cutting glass
They are flat , shouldnt cost you any more than about $50 for a new piece - take the other one out and use it as a template, they are the same left and right, just the bracket on the bottom of it goes the other way around.
Re: Cutting glass
yeah but when i go for a rwc and the mechanic notices there are no safety glass symbols on the glass it will fail.Blacky wrote:They are flat , shouldnt cost you any more than about $50 for a new piece - take the other one out and use it as a template, they are the same left and right, just the bracket on the bottom of it goes the other way around.
does anyone know whether they have tempered safety glass or laminated in the side windows. i am trying to research when tempered was first used in Australian cars as i found a site that says laminated up until 1970's but they may just be American i don't know
http://www.secondchancegarage.com/public/149.cfm
mmmmmmmmmmm dunno
Re: Cutting glass
You can get them cut from safety glass. Just make sure the symbol is on each one. A guy at work had all his glass cut for his spinner for less than $300 a few years back. All stamped and legit safety glass.
Re: Cutting glass
I thought they were the same,lh/rh, the inspector would be doing well to check for window marks, we only had 1/2 hr to do the check as any longer we were losing money doing regos. Let me know how you go with the glass.
Re: Cutting glass
Devilrod wrote:You can get them cut from safety glass. Just make sure the symbol is on each one. A guy at work had all his glass cut for his spinner for less than $300 a few years back. All stamped and legit safety glass.
the window guywe use at work is going to get me a prie to get them made i will let others know the price when i get it if anyone is interested
mmmmmmmmmmm dunno
Re: Cutting glass
Try American Muscle Car Glass in North Croydon Vic
Kel
Kel
Re: Cutting glass
it's cheap as shit to get them made they could be cut from laminated (you can get this with the approval stamp) but it's not recomended for doors as it can crack from continual closing the door
when i did the 2 door i was quoted less than $100 a square meter (enough to do the 4 windows) for the heat treated glass then she said a bit extra for cutting and beveling (done before heat treating)
bootlegger
Re: Cutting glass
K and k glass at arndell pk cut and temper glass. I use them all the time for my glass work.
Re: Cutting glass
i think that was the place that quoted mebootlegger wrote:K and k glass at arndell pk cut and temper glass. I use them all the time for my glass work.
Re: Cutting glass
thanks guys that been a great help i think i will get some made when the time comes the help is greatly appreciated
mmmmmmmmmmm dunno
