Front Brake Drums anyone?
adsman
Post by adsman »
Has anyone got a set of drum brakes for an EK front? Had a minor issue with losing a front wheel resulting in a grounded down backing plate and brake drum or any suggestions on a easy disc brake conversion? I have checked out the Castlemaine Rod Shop conversation kits, does anyone know much about these?
Re: Front Brake Drums anyone?
What side do you need ? Should be able to help out.
adsman
Post by adsman »
Front passenger side would be great?
so just a drum and backing plate ??? call me on 04 1960 61 62 if you want.
adsman
Post by adsman »
Will do. Cheers
adsman
Post by adsman »
Can anyone tell me if a backing plate off an FE/FC will fit on an EK? Should be the same?
