Help
Marko
Help
Post by Marko »
Hi guys,
wondering if anyone can provide a measurement for the distance from top of V8 trimatic dipstick to the level indicators at the bottom.
Also are V8 and 6cyl dipsticks the same length.
I had a coupla issues on the way back to Mandurah from the All Aussie day in Waroona, 1st issue was I sucked the sump gasket into the sump which created a pretty bad oil leak and loads of smoke, also pretty bad leak from the trimatic pan - i reckon there to much trans fluid in there. Hence why I want to check dipstick specs.
As for the sump gasket - very much hoping i can replace it without having to pull the engine out. XXXFingers crossedXXX
FBVANDAM
Re: Help
647mm from where the dipstick bit goes into the bottom of the handle to the tip of the dipstick.
Marko
Re: Help
Post by Marko »
Thanks Blacky,
hey why would my sump gasket get sucked into the sump (just between 2 bolts), i would have thought if anything it would get pushed out.
FBVANDAM
Re: Help
Marko wrote:Thanks Blacky,
Sounds like the crankcase got under vacuum. Is the air inlet for the crankcase (either PCV feed line from carb or road-draft tube) blocked?
Marko
Re: Help
Post by Marko »
I didn't have a breathable cap on either rocker cover, just the PCV valve and hose to carby. I have now put a breather on the opposite rocker cover, you reckon that should do it?
FBVANDAM
Doc Bob
Re: Help
Post by Doc Bob »
You got it Marko....PCV sucking air hard through the carb and no breathers to let any air in.....somethings gotta give!
Hope you get it all sorted again ;)
'36 Chev Pick-up
'40 Chev Coupe Ute
'62 EK Wagon
'63 EH Roadster
'68 F#*d Fairlane
'76 LX SS Hatch
Marko
Re: Help
Post by Marko »
Damn, wish I knew that 2 weeks ago. This build has been a massive learning curve for me, and its ongoing. Thanks for the help to those who commented.
Worked out my dipstick in the traumatic was about 27mm short - that explains the continual leaking I guess.
thanks again guys,
Mark :thumbsup:
FBVANDAM
