NASCO and Other Fitting Instructions - post here.
Re: NASCO and Other Fitting Instructions - post here.
You ought to stick that Nasco dust on Epay Alan
Blacky wrote:You ought to stick that Nasco dust on Epay Alan
I might just try that!
I sold one of those NASCO PoliMops for a small fortune a few years back.
A little sachet of NASCO dust would be the perfect accompaniment
Alan
sweet!)
Hi guys,
I have a HK and am desperately chasing fitting instructions for the nasco bonnet spear / hood ornament.
Its probably a long shot but no one on here would have a copy or any information about measurements would they?
Thanks!
Andy.
Thanks!
Andy.
A few more:
M35500 Rear vision Mirror Weathershield mounted (FX-HR):
Airchief radio speaker (FB):
Timing cover seal (all grey motors):
Sunshade (FB/EK):
Sunshade (FB/EK):
Thanks Harv. Just reading the first 3 words of line 1 made me put it in the too hard basket
- Joe_FBHolden
I tried fitting the sunvisor and brackets last night but came across an issue. One of the previous owners covered up the holes on the roof, when I carefully drilled the centres out (masking tape down first) it opened up to the size of a 5cent piece. Its only the rear holes on each side. Any suggestions on repairing the holes before attempting to refit the sunvisor?
Never used a nutsert, but suspect they may solve your problem. Gives these guys a call:
http://www.rivtec.com.au
Yu might be able to use wellnuts Joe ?? They are what I used on my ute - here is a link to a site , they are available locally I just found this to give you an idea of what they are if you are not familiar with them already. Being rubber they seal the hole as well.
http://www.calsci.com/motorcycleinfo/WellNutsprod.html
- Joe_FBHolden
Thanks for the advice guys, heres a pic of the damage so far
- Joe_FBHolden
- Joe_FBHolden
Looks like the nutsert may be the way to go. Similar to a rivet gun but bit different. Apparently anyone who works in sheet metal has one. Anyone have contacts in the Canberra area???
- Joe_FBHolden
All fixed!!! Sunvisor all mounted and sitting proud
- uploadfromtaptalk1417239901283.jpg (75.63 KiB) Viewed 6737 times
- uploadfromtaptalk1417239881909.jpg (73.48 KiB) Viewed 6737 times
what did you end up using mate ? we use nutserts at work but I don't know how waterproof they would be ......
- Joe_FBHolden
Hey Blacky, I used speed nuts and a combination of the old flathead screws and the zenith metal screws. I test drove it at 80 kph and no movement what so ever. Not my first choice in fixing the problem but for $10 it worked.
