EK JAY'S FB WAGON PROJECT (some color)
EssCee
Re: EK JAY'S FB WAGON PROJECT (some color)
Post by EssCee »
This has been by far the best build for me to follow!!! Unreal mate
SunnyTim wrote:
EK JAY wrote:As for the Nats stew yep the pressure is on :ebiggrin:
2015?
He still has 12 days ......... get into it Jay :ebiggrin:
EK JAY
Post by EK JAY »
Yep if your looking for me im in the shed :lol:
at this stage its 2015 :frown: :)
EK JAY SINCE 1990
EK JAY
Post by EK JAY »
Hi
still progressing slowly
any way made up some exhaust headers and got good clearance around stuff i will get them remade in stainless
once i get the motor to turn key stage
EK JAY SINCE 1990
:thumbsup:
EK JAY
Post by EK JAY »
Thanks Mick :thumbsup:
i also got the engine mounts done rhs box with crush tubes
and new HT brake master cylinder fb ek pedal box and HTKG break away steering column bracket sorted :gasp: :ebiggrin:
will chuck up some more pics soon
EK JAY SINCE 1990
NoMAD
Post by NoMAD »
looks like the hard parts out the way there mate
good job :thumbsup:
cheers
Nathan
Foundation Member
EK JAY
Post by EK JAY »
:D Thanks Nathan it did take a few days on and off of cutting and welding them to get them right
also got the radiator in a good spot I had to recess it into the support bar a bit
because ive got the motor forward a bit more so I can run the column shift auto set up but its all coming together now
feels like im getting somewhere at least :ebiggrin:
EK JAY SINCE 1990
Nice work Jay, does not look like it was fun...
EK JAY
Post by EK JAY »
:ebiggrin: aahhhh your right there Brett but I reckon first drive with the plates on I will forget all that sort of stuff :lol: :ebiggrin: :ebiggrin:
EK JAY SINCE 1990
EK JAY wrote::ebiggrin: aahhhh your right there Brett but I reckon first drive with the plates on I will forget all that sort of stuff :lol: :ebiggrin: :ebiggrin:
never has a truer word been spoken :wink: 8)
EK JAY
Post by EK JAY »
I have moved the front mounted rack down level with the pivot pins on the crossmember
and according to my bump steer measure stick thingo majig I have zero bump steer at ride hight :thumbsup:
8) :peaceout:
EK JAY SINCE 1990
Sweeeeeett 8) 8) 8) 8) 8) 8) 8) 8) 8)
We need LOTS of dimensions , pics and info pleeeeeeezzzzeee :ebiggrin: :ebiggrin: :ebiggrin: :ebiggrin:
EK JAY
Post by EK JAY »
yeah no worries blacky I will put the measurements up once I get it welded up
not just tacked in :thumbsup:
got my hoodline from the trimmer today :thumbsup: need to put my seat belts in then I can fit it up
and put the wind screen side back windows in and doors back on carpet and door rubbers in
fuel and brake lines some wirring ahh list is gettiiiiiing smaller :clap: :thumbsup:
EK JAY SINCE 1990
EK JAY
Post by EK JAY »
have tried a few different door trim design's and came up with this one has the wood in between the chrome and will probably put
a eh front gaurd special badge down the bottom at the front just above the chrome strip when I find 4
i will be using the same colour vinly as per the seats and arm rests that I made (cut down front one)
the colour of the mdf board im using is close to the seat colour so it gives you an idea on how it will look minus the tape :ebiggrin:
still need to pull the vinly tighter on the arm rest aswell
also some pics of the front end with the Rack brackets and engine mounts on
:ebiggrin: jay
EK JAY SINCE 1990
