I have a question relating to checking the valve timing on the grey motor ,..I'm currently replacing the timing cover oil seal and are contemplating changing the Timing gear as well ,..
The How to Guide is great and explains everything about how to do it ,... so before I take the cam and everthing out, with the timing cover off i thought it would be a good idea to align the timing marks on the cam & crank gears
and check /align the flywheel timing /TDC marks,..
On my engine ,... in this position the distributor rotor is firing # 6 ??,...I thought it would be firing #1 ,... checking #1 it is found to be " on the rock " ??,...
When I rotate the engine by hand ( Clockwise ) and get # 1on its compression stoke with the flywheel timing / TDC aligned,.. the distibutor rotor is correctly positioned pointing to the body mark firing #1 ,... #6 is on the rock as it should
be ,.... but the cam & crank marks are exactly 180 degree opposite each other ( counted the teeth to confirm ) this seems wrong to me ?.....i thought they should be aligned in this position
Could the Cam or the distributor have been assembled incorrectly previously ??,.. or am I not understanding something
I haven't gone any further as i want to understand this better ,... by the way the engine was running ok before it was taken apart
Can someone help ?,....
Also a replacement timing gear is with spares that i got with the car ,... the Holden Part no on it is 7414429 ,.. the existing one has part no 7414360 ?,..... but they look the same ,.. is this one for a different engine ??,..
Kel
