5 speed conversion
iso007
5 speed conversion
Post by iso007 »
Hey guys, i have a crash box column shift ek with a 186 motor. i can get a 4 or 5 speed box with adaptor plate from several sources. i know i will need to change the tunnel to the higher, auto type and i can get the rear gearbox support mounting from several places also. So here is the question. What is the most common or easiest way to strengthen where the original tunnel came out. it seems that the original tunnel has a strengthening peice noticeable from inside the cab. I saw that one guy has made up like a saddle of flat bar which goes over the box and then made his tunnel to fit over that. Is that the best. Or is there a premade unit available. or am i barking up the wrong tree all together. i have searched the forum but can't find what i am talking about.
thanks
Ian
Re: 5 speed conversion
Castlemaine Rod Shop or Waddingtons will sell you a weld in enlarged transmission tunnel , you will need to fabricate your own bracing where you cut the original brace out , typical halfa job aftermarket bits :roll: :roll: :roll: :roll: :roll:
iso007
Post by iso007 »
ok, Thanks blacky. i was kinda thinking that was the case.
Ian
Smooth customs
Post by Smooth customs »
Dellow Automotive at Revesby are a lot closer to you, and can supply everything you need.
And no freight costs.
I wasnt aware that Dellows sold the weld in transmission tunnels ?
iso007
Post by iso007 »
Thanks guys, i called in to dellows yesterday as they are in the next street to where I work. They don't sell the tunnel or the strengthening set up, but they sell Everything else for the conversion and have been a really good company to deal with in the past. I will just make the support brace. I just didn't want to re invent the wheel.
Thanks
Ian
The tunnels are brilliant! it will save you time and money as factory auto carpet fits, for mine we made a piece up which went underneath to replace the similar bracing we took out.
