FB/EK SEDAN BULLET TYPE REAR LIGHTS
adell'e 1969
Post by adell'e 1969 »
G'day I saw a fb sedan in a picture that had bullet type looking rear lenses. Does anyone know if they still are available ??? sorry my description is pretty shit , mick jaggers custom sedan seems to have that type lights on it ???
cheers Tony 0467 685257
Mai Ki-Ki
Re: FB/EK SEDAN BULLET TYPE REAR LIGHTS
Post by Mai Ki-Ki »
http://www.classicplastic.com.au/catego ... ategory=10
Reminds me I need to get some too.......!
The Kardinals, Melbourne.
Mai Ki-Ki wrote:http://www.classicplastic.com.au/catego ... ategory=10
I run a set of these on mine. You need to do ne of two hings when you get a set unless they've changed since I bought mine. Either buy longer screws or sand the base down to thin it out as the plastic is thicker than the originals. Mine are around 9 years old now and no issues with fading either.
adell'e 1969
Thanks Very Much Guys I will order a set this weekend and get some longer screws and I will let you know how they fit :thumbsup: :thumbsup: :thumbsup: Cheers again Tony
I should add I sanded mine down. It doesn't take long just rwrap some sand paper over a flat surface if you do plan to thin them down.
Doc Bob
Post by Doc Bob »
The only mods I had was to slightly enlarge the bolt holes.
Other than that, very happy with their parts. Also fitted the Wagon rear Number Plate lenses, they were a perfect fit :D
Highly recommend their gear to anyone. :thumbsup:
'36 Chev Pick-up
'40 Chev Coupe Ute
'62 EK Wagon
'63 EH Roadster
'68 F#*d Fairlane
'76 LX SS Hatch
Stationsedanman
Post by Stationsedanman »
Had to enlarge the screw holes and file the edge of the lense to make mine fit too. Bit disappointing when you fork out that much cash. Had to use longer screws too, as previously mentioned. Not sure if they've fixed this in the last 18 months since I fitted mine. :esad:
