HELP FOR WIRING RED MOTOR
basic.green
Post by basic.green »
hello all.just a quick question on electrical system (red motor). purple wire comes from under dash (ignition starter switch ?) and goes to shifter (neutral safety switch?) then to starter motor is this correct ?any help would be very appreciated
Sounds right , if in doubt, remove the battery and power it up using a cheap battery charger, that way if it is wrong , the battery charger wont have enough grunt to smoke up your wiring harness.
basic.green
Hi all. thanks blacky for your help.a little early to connect battery as in very early wiring stage. but will keep in mind. thanks rick :D
