Indicator problem
EKfanPaul2
Indicator problem
Post by EKfanPaul2 »
hi guys,
I've got a problem with my indicators.
They'll work when the car is not turned on but not started, but as soon as she is started up / just drive a couple of blocks; they die.
I've replaced the flasher can, the fuse, checked the wiring to the fuse panel.
Can't see anything wrong
Any ideas.
cheers
Paul K
MeFB
Re: Indicator problem
Post by MeFB »
What mods have you done to the electrical system? Has an alarm been added?
:arrow: :D
Alan
EKfanPaul2
Thanks guys, not moded, only a taped off wire to a radio that is not wired up
I cleaned all teh connectors on the fuse panel
Paul
tm 50
Post by tm 50 »
Mine do the same thing only the front , it was that little fuse type connection near the terminal blocks in the engine bay ,
EKfanPaul2
The majician Bill (Reidy) worked it out.
For some reason the yellow constant power cable from the column was rubbing against the steel brake light switch housing; earthing out in the process.
Even though it was insulated - it was earthing out
Well done, that man!
Paul K
