That's a nice looking outfit you have scored there.
regards
HAhahaha, just answered my own questionEJ and EH Body and Engine ID Codes explained
From a set of numbers we can establish some of the history of your EJ or EH. It is all relative to the amount of info you have. I will go through examples and explain what they mean. First of all I will start with the chassis number it is NOT the little tag below the BODY ID tag. It is found stamped in the engine bay skirt panel on the drivers side. A typical example would be 'EH12345M'. The first two letters will state simply whether the vehicle is an 'EJ' or 'EH' .The numbers that follow indicate the number for that vehicle off the line at the plant it was built and/or assembled at. The chassis numbers started at 1001. This brings us to the final letter, which will be either
A - Adelaide
B - Brisbane (assembly only)
M - Melbourne
S - Sydney
P - Perth (assembly only)
NZ - New Zealand (assembly only)
Sorry for the late reply mate. Yes, I did.muza wrote:Did you end up buying the heater of blacky mate?
I might be interested if you didn't
