anyone used this product from this supplier
http://www.ebay.com.au/itm/Holden-FB-EK ... 20c9ce97e7
Headlining
Headlining
Re: Headlining
Nope, my headliner was one of the few things I did get off eBay but that was from Supertrim in Coburg (Vic).
- Contact:
Re: Headlining
Give Daniel a call before you order anything.
Re: Headlining
Yeah I just did that....parisian62 wrote:Give Daniel a call before you order anything.
He is doing my sedan anyway Stew I already arranged that with him.
Same deal as with you mate.
The reason I asked is that my other FB Sedan will need one too.
I saved the bows from Reddos Newcastle Shed find, I figured they would be hard to get down the track...
But I need the get a second one made for my other FB Sedan and I need to know where the bows will go cause there not marked.....
I should be able to match them with the other headling before it goes into the green FB
Well there wasen't much material left when I got Reddos FB and didn't have time to mark them....
I couldn't even get the wiring loom out of that car it was rooted too!...
Re: Headlining
I got a headlining in the shed with the bars still in it if you want me to measure each bar from say front to back , if that helps mate ...Fingers
Re: Headlining
Thanks Bill but I figure I can pull one bow out at a time and match it with the other onefingers wrote:I got a headlining in the shed with the bars still in it if you want me to measure each bar from say front to back , if that helps mate ...Fingers
Can't be that hard...
