Weber Carbies
JOD34N
Re: Weber Carbies
Post by JOD34N »
Yep...the one & only.
I shoot little furry animals with a big Canon!!
JOD34N
Re: Weber Carbies
Post by JOD34N »
Carby has arrived & the manifold should be here early next week :thumbsup: :thumbsup:
Dean.
fingers
Re: Weber Carbies
Post by fingers »
JOD34N wrote:Carby has arrived & the manifold should be here early next week :thumbsup: :thumbsup:
Dean.
my carby arrived this week too ...the manifold will be next week too .are you using a sonic manifold ...Fingers
JOD34N
Re: Weber Carbies
Post by JOD34N »
Not using a sonic manifold Fingers, hopefully mid week I will have some pics of my set-up.
Dean.
JOD34N
Re: Weber Carbies
Post by JOD34N »
Well fingers, here is a pic of the new manifold. can't wait for it to get here so it can be fitted up.
Dean.
fingers
Re: Weber Carbies
Post by fingers »
JOD34N wrote:Image
Dean.
Looks good mate ..i have seen one of these before ....will you have any clearance issues with the bonnet mate ...Fingers
ek61
Re: Weber Carbies
Post by ek61 »
8) 8)
***just cruise***
JOD34N
Re: Weber Carbies
Post by JOD34N »
just sorting out the linkages...PITA!!!
fingers
Re: Weber Carbies
Post by fingers »
fingers wrote:
FB MAD wrote:I fitted a Weber carb from a two litre Cortina ( 32/36 Weber I think ?? ) on to my wifes ( Grumblebum's ) KE70 Toyota Corolla that she had years ago ( I'd fitted a bigger imported Jap 1500 CC engine as opposed to the 1300 CC original ) .
There was some improvement but not overly great , probably because the engine was stock and unmodified and strangled with it's jap pollution spec cam and other parts.
I'm sure if I'd cammed it up, and improved it's breathing in other places , it would have had a fairly dramatic improvement.
My thought's / experience,
Thanks for the comments mate ......the motor I have to fit up with the weber is a grey with 82 grind cam .bored to 3 and 3/16,decked ,balanced , blue printed , heap of porting work and large valves and running a trimatic transmission ..I been looking at these new weber manifolds on ebay with a 32/36 or 38/38 weber and thinking how much easy to tune than twins or triples and probably more tractible with progressive linkages as standard ...not real old school but should make a hot grey run and idle a lot smoother and as you say that induction roar is cool ........Fingers
Havent got the weber manifold yet so .....had the motor sitting in a frame ready to rumble ..Couldnt help myself, so fitted up some twin strommies and arc,ed her up ......man....... that rough idle ,very quick throttle response and straight out the extractors sound ....Jayuus, I,m excited ....dont know about the neighbours tho ....how do ya post a video clip here.............Fingers
JOD34N
Re: Weber Carbies
Post by JOD34N »
Looks good Fingers, I took my car for a run the other day. It's running a bit lean on the idle jet so I have ordered a couple of bigger sizes to try out. I ended up doing a cable conversion as well...wasn't that fun trying to get it sorted. I couldn't get the cable to pull the butterflies open properly with the cable in a vertical position, messed around most of the day. Finished up using a stromberg choke cable holder on a small plate to get it working, only to find the arm on the bottom of the pedal wasn't pulling enough. Off with the arm & an extension piece welded in, bit of a bend for clearance & she's all good. Will let you know how I go with the jet sizes.
Dean.
fingers
Re: Weber Carbies
Post by fingers »
[quote="JOD34N.......... PITA .............Just sorting out the linkages...PITA!!![/quote]
The penny just dropped this very second :idea: :idea: ...PITA .......I been thinking bout it for days :lol: :lol: ...........
Anyways thanks for the update on the jetting mate ,please keep me posted .........Fingers
muza
Re: Weber Carbies
Post by muza »
Dean....you have a picture of my wifes car as your avitar :oops: :oops:
Stock as a rock
Not so stock
JOD34N
Re: Weber Carbies
Post by JOD34N »
Thanks muzza :lol:
Fingers, I am still playing around with trying to get the carby running right. When I get it sorted I will let you know jet sizes ect.
Dean.
fatboy66
Re: Weber Carbies
Post by fatboy66 »
Fingers,
can you post a pic of the weber manifold when you get it please.
Tavita
choppedfan
Re: Weber Carbies
Post by choppedfan »
JOD34N wrote:Image
Dean.
Dean,
Who did the adapter and can I ask how much?? I've got an SC14 I've been tinkering with to set it up on a grey and that adapter could be just the thing if I mount the blower on the sideplate side similar to how they mount them on red motors :thumbsup:
Mick 8)
