Just to clarify it is the height of the sidewall (profile) that is the main determining factor, this subject has started debate on hotrod sites and other early Holden forums I guess in the end its an individual choice and its good to see it mentioned occasionally so anyone contemplating running them can see the pros and cons instead of listening to the guy who sells themMeFB wrote:The MAXXIS 80 profile MA-1's have a '420' Treadwear Grade, and a 'B' Traction Grade, which indicates a quite a hard-compound tyre. I would have thought they would be less likely to be damaged by the flappers![]()
Maybe it's the harder compound tyres that get more affected![]()
Sorry to hear your tyres are cactus![]()
You probably know Maxxis do the 185/80/R13 MA-1 in a whitewall, but it's a thin band.
