Grey motor heads
Grey motor heads
Are the all the same ?
Re: Grey motor heads
From what I understand, they are similar, though some changes were made mid-FJ that makes pushrod length different, and another change at FB that incorporated a heater water outlet hole. May well be more changes.
Harv.
Harv.
thanks harv,went and had a look at a ej wreck had the head off the motor plus another spare might work one up, when say doing a grey motor up raising compression to zero the block or shave the head is preffered just wondering...
I've been thinking the same thing... I've got a grey motor sitting on an engine stand, and the temptation to work it up and fit triples is getting the best of me. I worked out that I must be nuts when I caught myself bidding on the eBay triple Strommie manifold - need to finish the V8 project first
The easiest way to go would be to buy Fingers head and go from there - would probably save several hundred dollars that way:
http://www.fbekholden.com/forum/viewtop ... =2&t=15990
Harv.
Harv.
choppedfan
C'mon Harv,Harv wrote:I've been thinking the same thing... I've got a grey motor sitting on an engine stand, and the temptation to work it up and fit triples is getting the best of me. I worked out that I must be nuts when I caught myself bidding on the eBay triple Strommie manifold - need to finish the V8 project first![]()
Harv.
Come over to the world of vintage speed,
There's nothing better than going fast slowly
- phpPRkVNuAM.jpg (45.06 KiB) Viewed 3136 times
getting even more tempting might pull the motor out of my ute for a freshen up and put aside , and go get that block out of the ej and work that...
whats some hp figures from worked grey motors?
How worked?
Cross flow heads? ~150hp +
Non cross flow < 150hp with lots of revs
Rotary valve heads upto 200hp
Probably around a 50% increase in power from stock on average, which would mean about 110bhp (about the same as a reconditioned stock 179). Not much really, but it does make a difference. It does not make for a fast car by today's standards, but a somewhat spritely one which doesn't die going up hills. In my opinion, you pretty much hot the grey up because your into period speed stuff; or you want to avoid having to alter the vehicle too much (e.g., disc brake front end, collapsible steering column). Hotted up greys also look good and sound sensational. But you can get far more power from a red motor for the same money, and even more from a V6.browno wrote:whats some hp figures from worked grey motors?
And thats way we love gray motors! It's cool and different. If I want a fast car I'll get a SS for 15 grandStygian wrote:But you can get far more power from a red motor for the same money, and even more from a V6.
I found my emails from Rod who does teh reproduction Xflow heads and with his head and cam setup thy say you can get 200+ bhp. Thats what they claim anyway.
Yep and you'd get half decent chassis dynamics, suspension, brakes and handling - and all without getting it engineered.GreyFC wrote:If I want a fast car I'll get a SS for 15 grand
I'm doing my research on building my own hottie grey and, as usual, I have given it way too much thought
The question I asked my self is; "when does a grey motor stop being a grey motor"
I decided that I would keep the major components original and just work on them to get the best (driveable) performance.
One interesting mod that I've seen is adding roller rockers. Not sure how well that worked long-term without hydraulic lifters, but still a very interesting idea
The biggest thing I'm toying with is a low-boost supercharger, maybe a vintage Paxton? Teeheehee
Alan
sweet!)
Well, in that case, you should have bought Steve's Snowcrest White / Cameo Beige EK sedan that had the Cameo flashline flashkit. It had a mild grey (twin Strombergs, 25/65 cam) and it was quite drivable and spritely. I know because I used it as a wedding car.MeFB wrote: I decided that I would keep the major components original and just work on them to get the best (driveable) performance.
choppedfan
As far as superchargers go you can forget Paxton blowers unless you've got plenty of $$$$$$$$$$$$$$ a good alternative is the SC14 found on Toyota's, I've been looking at these for a while now and there are kits to make them a "bolt on" to red motors. Relatively cheap and they are reasonably plentiful they seem a good thing (to me anyway), I'm in the throws of putting my old 36 F O R D back on the road but will take a serious look at the SC14 option for the grey in my ute when the 36 is finishedMeFB wrote:I'm doing my research on building my own hottie grey and, as usual, I have given it way too much thought![]()
The question I asked my self is; "when does a grey motor stop being a grey motor"![]()
One interesting mod that I've seen is adding roller rockers. Not sure how well that worked long-term without hydraulic lifters, but still a very interesting idea![]()
The biggest thing I'm toying with is a low-boost supercharger, maybe a vintage Paxton? Teeheehee![]()
Sorry for getting of the original subject of grey heads
