Boosted brakes with a manual
I want to run a booster on the fire wall of the ute like the pic below.
It's got a HK off set bracket to move it away from the bonnet hinge, but it covers the clutch hole also.
Can the clutch master cylinder be moved over at all?
The reason I want this setup is it works extremely well, this one is on the wagon and I have the same on my sedan, most braking is done with one toe :thumbsup: .
rosco
Re: Boosted brakes with a manual
Post by rosco »
Not sure, Trev....
I know Michael S fitted a pushrod brake booster assembly to his FB... he made up a box which moved the booster out beyond the hinge assembly.
This allowed him to use the hydraulic clutch.
He had to make up a pushrod from the brake pedal to reach the booster. It ran through a bearing inside the box to support it.
Haven't seen him for a while - but should be able to chase him up if you need any info.
Thanks Rosco, I was thinking that might be the only way to do it.
Not sure if I want to have the booster sticking out that far though.
Bluehaze
Post by Bluehaze »
Hi Trevor.
I just went and had a look at my setup, which is pretty much identical to your wagon. I reckon you should go and check out the wreckers to find yourself a really small in in one of those Korean cars or something. Maybe with a bit of creative welding you can fit one beside the offset bracket behind the booster.
Good idea, might do a bit of investigating :think:
You could make it look like an old Escort... Two foot booster bracket :mrgreen:
Re:
Devilrod wrote:You could make it look like an old Escort... Two foot booster bracket :mrgreen:
Or not :roll: :P
Been having a troll through some car sites :wink:
I have seen a setup with the booster on the inside of the firewall and the master cylinder in the engine bay, do you think this could work?
Bluehaze
Post by Bluehaze »
Sounds weird. I'd be inclined to be making creative relocations for the clutch master. (I reckon the brake booster is protruding enough!) I saw a pic on a hot rod site where the cylinder was mounted lower down (so the push rod travels at an angle, the cylinder was also angled, but it had a remote reservoir, which you could mount wherever you liked. Or perhaps modify the pedal box so the master can be inside, again with a remote reservoir. A bit like this one.
