Need ID of some parts
Re: Need ID of some parts
1. correct 4 hubcaps :thumbsup: other 3 EK worth nothing up to what the idiots pay $50each
2.rear sway bar probly any early holden, usually good money on ebay
3. red motor oil pump once again worth nothing, except if there is a large cross on the other side then maybe $50 up
4. no idea
5. sports mufflers look like 2" but hard to tell maybe $50 - $100 i'll give you $20 if they're straight through 2" and yor goin to clarendon
6.top bar here bonnet locks down on FB/EK goes from side to side between guards maybe 0- $20
7.gearbox cross members to suit hadfield chassis kit
8. push in oil cap for aftermarket chrome rocker cover, water neck from holden V8 other bits no idea worth a couple of bucks
9.fabricated gearbox crossmember at a guess out of EJ/EH possably could be used in auto body EK once again a few bucks
10. might be the rare EK mnaual heavy duty radiator as it looks like an auto one but seems to have dfferent part No and only 1 outlet
11. i think is EK auto
12. EH auto
all radiators 0 - maybe $50
13. part of a hadfield chassis kit goes on subframe where front end bolts up, worth probly nothing
WayneXG95
Post by WayneXG95 »
Thanks Mick, anyone else?
MeFB
Post by MeFB »
Those wire/spoke wheel trim thingys would have to be worth a buck or two on ebay? I haven't seen anything like those before.
:arrow: :D
Alan
WayneXG95
Post by WayneXG95 »
WayneXG95 wrote:4th up 4 wire type hubcaps, no id name or numbers?
Been advised these have been seen on EK's years ago..Need dress rims to attach to wheel...and a moon style insert...might be why I have one.. :)
ek61
Post by ek61 »
NO 4
they are fruit bowls you just have them upside down :)
look like wire wheel inserts to me but wouldnt have a clue what the would be off 8) 8)
***just cruise***
WayneXG95
Post by WayneXG95 »
I'D the wire wheel covers. 56 Chevy. Be checking if I can restore them.
resto
Post by resto »
Here you go - you need the outer rim to make them worth anything - It is a very thin dish shaped rim
Resto
WayneXG95
Post by WayneXG95 »
Guess I better start looking. Anyone got these? :D
