I am going to be putting in a New FB Trunk/Boot Floor Pan, which I have not sourced yet.
is there any diagram that shows where to cut it out because one of the suppliers has asked that I supply the existing one and he eill make it 20mm bigger, would it be better to have it made so it sits on the left and right chassis rails?
James
FB Trunk/Boot Floor
FB Trunk/Boot Floor
James
WOWU
Penrith NSW
James
WOWU
Penrith NSW
Re: FB Trunk/Boot Floor
I have recently done one. Got a rear cut, drilled out the spots and replaced the old one.
All i can say is be prepared for a big job. there is a mountain of spots in those boots!!!!
once again be prepared, no be very prepared for a big job!!!
once its done though youll be glad it is.
mine now looks like it came out of the factory with it
i am a little bit fussy though.......
good luck with it and dont be afraid to drop me a pm if your stuck
cheers muza
cheers muza
Stock as a rock
Not so stock
Stock as a rock
Not so stock
the boot floor is spot welded along the top of the rails
Stock as a rock
Not so stock
Stock as a rock
Not so stock
Hey James, Muza lives near the princes hwy .........if ya pm Muza you may be able to call in and have a look if hes gunna be around about the time your travelling thru Gippsland ....I,m sure Muza wont mind showing you ............Fingers ...
Re: FB Boot Floor
Thanks Guys
I'll have to check it out once I get back.
I spoke to the owner at Spectrum last Thursday and recommended that he run the FB Boot badge he has agreed, he's very keen to see what he can do to become a prefered supplier to the FB EK car club.
I go both front floor pans from Spectrum and only paid $55.75 each + GST
James
James
James
WOWU
Penrith NSW
James
WOWU
Penrith NSW
