commodore motor or grey?
Lurch
Post by Lurch »
Gday guys,
I'm new to all this posting and stuff so please bear with me :) My question is simply this....My EK has been blasted and primed now I'm at the decision stage. Do I fit the 138 grey or go all out with a commodore V6 or V8? I also was wondering for those out there that have dropped in the commodore motors what sort of problems have you faced before? i rang V6 conversions and saw the great new front end they have but the problem is 6k for it delivered to my door so If i go this way I wanna be sure its gonna fit properly with little hassle from engineers. Any sharing advice is greatly appreciated thanks guys.
Cheers lurch
John
Re: commodore motor or grey?
Post by John »
You'll get all sorts of replies to that question mate :)
I guess I see it as, if it's original stick with the grey, if you are modifying the body you might as well spoil it with a crumadore motor :)
You can probably guess my is staying as a 138 :)
ingredient in beer
Bluehaze
Post by Bluehaze »
Lurch,I guess you need to see the bigger picture if you are going for the v6 or v8. Apart from the obvious engineering issues, you also have to worry about steering, brakes, boosters, fuel delivery, and electrical (what did I miss).
That said, if money and time are not such a problem, I'd go for the v6 for the driveability and the extra poke of the efi system. The whole original looking modern running car is a winner in my books.
Also comes down to what you want to use the car for.
If it's a daly driver I'd go for the V6 or V8.
As a weekender the 138 is great, Trev.
why does the body have to be modded to have a modded engine :? :?
it's pretty much what trev said BUT mainly depends on what YOU want,
for me i do pretty much only highway driving i like to get to the speed limit or a little over quickly and cruise there and overtake whatever gets in my way ASAP so a grey motor is of no use to me
Lurch
Post by Lurch »
Thx guys was thinking along the lines of what you said harry186. I like a neat orignal looking car but with the modcons so i guess a sleeper. This v6 converter frontend has the steering mods included so you can run power steering which is a great bonus. Also comes ready for you to put the discs from your donor car (VN to VY) straight on however as mentioned earlier cost factors on 6k i wanna be sure it works so if anyone has used one or is installing one please let me know.
cheers Lurch
John
Post by John »
harry186 wrote:why does the body have to be modded to have a modded engine :? :?
I dont think anyone said it had to.
IN MY OPINION if you modify the body you may as well change the engine.It's only my opinion. After all Lurch did ask.
If its a stock standard EK with standard wheels e.t.c then I'd go with the 138.
If its had door handles shaved, big wheels lowered e.t.c then I wouldn't run the grey.
ingredient in beer
fb cruzn
Post by fb cruzn »
lurch, you dont have to use the 6k front end, can use modded hr one. but the 6k one is 8)
Lurch,
Spend a couple of nights forum surfing - there are a heap of front-end options, some at the $6k level and some a damn sight cheaper. Equally, some front ends have good handling, and some are renkowned for poor turning circle and/or bump steer.
Maybe start here: http://www.fbekholden.com/forum/viewtop ... 25&t=12741 (you owe Jimmy a beer for pulling it together :mrgreen: )
Harv.
Lurch
Post by Lurch »
thanks Harv and Jimmy :)
Cheers lurch
