Generator to alternator conversion
Can anyone help me, I want to convert my car (grey motored EK) from Generator to Alternator, I have made a custom bracket to mount the alternator to the grey motor, and have mounted it but have no idea on the electrical wiring of it????
Thanks
Thanks
Hi newby.
The wiring is even simpler, if you're using a modern alternator with an built-in regulator. These were fitted to all Holdens HJ & later.
Unwrap the harness between the old reg & gen & follow this.
The only 3 wires that matter are:-
1. The thin brown wire that goes inside to the dash (gen light). Connect this to the spade terminal on the back of the alternator. You may have to extend the wire to reach.
2. The thick red wire at the old reg. Connect this to the bolt-on +ve terminal at the back of the alternator. You may also have extend this one too.
3. The one everybody forgets. Run a new thick black wire from the alternator bracket (or any bolt on the block or the head) directly to the body. Use one of the old regulator mount screw holes.
Dr Terry.
Dr Terry.
Thanks guys,
I think I have a later model alternator with built in reg, as the unit has a D+ and D- with a plastic plug socket at the top, and a bolt on post labelled B+ and on the lower half of the alternator is a D+ terminal all on its own??
see picture below,
So then where would I need to connect the wiring to these terminals, I assume the post is for the thick red wire, the spade terminal should I use the lower one or one of the ones in the plastic plug type set up?? (+ or -) and then run a wire to the body from the bolt??
Hope this is correct????
can you tell I am hopeless at electricals????
Newbie
see picture below,
Newbie
Hi Guys.
That's an HQ alternator .
It will need an external regulator.
Follow the wiring in an HQ workshop manual or see an auto electrician, or get a later model one & follow my wiring.
I forgot to mention this earlier, but there are 2 common brands of alternator used on Holdens, use the Bosch & not the Lucas.
Dr Terry.
Dr Terry.
Ok bought a later model alternator from the local wreckers, and think I have worked it out, see picture, Dr Terry do I bypass the firewall mounted regulator completely??
and please confirm this is correct labels in the picture
Newbie
P.S. this is my first car and I hope to have it restored for when I get my licence!
Newbie
earlyholdenfan
Hi Newbie,
Sounds like you need the basics here,
Yes remove the old regulator if you wish as it is superceded by the new alternator inbuilt one, The wiring as shown by Dr Terry is correct for the later type and will work perfectly. it is a very simple operation, but I understand your hesitation, talk to your wrecker, or call an auto electrician for any assistance, (if they are selling you parts they will help you out with info as well)
Matt
P.S. any chance of piccies of your ride????
Matt
Hoping everyone is finding my new Avatar less "Distracting" and of course it is not directed at anyone or anything either currently living or deceased, hopefully it may just be allowed to remain!
Re: Generator to alternator conversion
Going through the motions of this Generayor on a grey to alternator converstion. Have had a moble auto elect supply a new alternator that suits the same style belt with a built in reg. If anyone has any pics of the brackets (that they have mocked up) I'd really love to see them.
Thanks. Paul
Thanks. Paul
Changed the Gen and Reg to one wire alternator today. Made the bracket using a Holden red six alternator bracket with a few mods, pics below. The one wire alternator has 2 spade terminals marded #1 and #2, run the gen light wire (brown) to the #1 terminal and a heavy wire to the + (positive) on the battery. Remove the regulator and all old wiring as it is not required anymore !!
The front generator mounting bolt was replaced with a stud and nut.
I used the original Generator adjuster, reshaped it and relocated it to the water pump bolt obove the original one.
Hope this helps someone in the future...
Similar to what I did in the wagon
You will have to enter in the modified class now with all the red 6's and V8's
I'd better get a 3hp Nitrous shot then!!Trev wrote:Similar to what I did in the wagon.
You will have to enter in the modified class now with all the red 6's and V8's.
