I recently found out I got the car with an extra leaf in it already. So, here's the setup as it was:
13x6 rims, 205/65R13 tyres (Extra leaf):
Low-ish profile tyres add to the 4x4 stance.
13x6 rims, 205/65R13 tyres, Pedders Heavy Duty springs and 2 inch blocks (Extra leaf):
Had some wheel rubbing at the rear with the wide rims and 205s, so got some narrrower wheels...
13x5 rims, 185/80R13 tyres, Pedders Heavy Duty springs and 2 inch blocks (Extra leaf):
Looking at the sill height, it had a bit of a rake...
Had Moorabbin Spring Works reset the rear springs (lower @ 3 inches) to level it out.
13x5 rims, 185/80R13 tyres, Pedders Heavy Duty springs and reset rears (Extra leaf):
Getting the springs reset tidies up the back without seeing them hanging down - the rears alot stiffer (you notice the bumps!) but also tighter (less floaty). Now the exhaust is pretty well resting on the spring, so that's the next thing that needs doing.
