22inch Ek
SC00BB
Re: 22inch Ek
Post by SC00BB »
Very Nice work, I'd say you may need to re-use that jig for others going by the quality of workmanship.
DOLLER
Re: 22inch Ek
Post by DOLLER »
Hey Kid what time frame have you got from the engineer for the build??
kiid61
Re: 22inch Ek
Post by kiid61 »
Thanks Guys
No time frame Damien.... None of the engineers we have spoken to have mentioned anything about one. Has your engineer still put a limit on your build?
kiid61
Re: 22inch Ek
Post by kiid61 »
Stygian
Re: 22inch Ek
Post by Stygian »
Hey kiid,
Very impressive engineering. Just a question though. What do your engineers think of narrowing the track? My own (limited) knowledge is that car manufacturers like to get the track as wide as possible for stability and handling.
Andrew
matches
Re: 22inch Ek
Post by matches »
as far as i know, the track width of the original car (not the donor front end/ diff is the measurement that matters. so you should be able to increase or reduce disk to disk distance as much as you want as long as your offset of tyres puts the centres within a certain percentage from original.
cheers, luke.
Stygian
Re: 22inch Ek
Post by Stygian »
Cheers Luke. I thought the regs must allow a bit of leeway somewhere. The tyre offset is it.
Harko
Re: 22inch Ek
Post by Harko »
Its a definite no in NSW , But then .... consult an engineer for the up to date specifics :roll:
I tell you what though I wish it was OK over here it sure would save some hassle and $$$ :D
DOLLER
Re: 22inch Ek
Post by DOLLER »
Looking good justin. I'm tryin to go for Street Rod rego and was told to have it 99% done by the end of the year as regs were changing. Dunno how true this was though, will be gettin a second opinion
Re: 22inch Ek
That could be due to (hopefully) the 90 day permit scheme coming in Doller.
Nice work Kiid..
kiid61
Re: 22inch Ek
Post by kiid61 »
Thanks Damien + DR..
I recon its just your engineer man, shop around... From what you were telling me about it at my place that day it seems like he is a bit suss?? ( don't post his name or any other details up here )
kiid61
Re: 22inch Ek
Post by kiid61 »
Stygian wrote:Hey kiid,
Andrew
He says so long as the engineering is up to par and every detail of the modification is documented it should not be a problem.. Hopefully it isnt or else a lot of time has been wasted :lol: .... I'm confident tho
Thanks
kiid61
Re: 22inch Ek
Post by kiid61 »
Front end is almost complete, just need to finsh welding the bottom plate and then mount the steering + out rigger...
Totall is 60mm less track and will sit 50mm lower
kiid61
Re: 22inch Ek
Post by kiid61 »
Re: 22inch Ek
Post by Mick Jagger »
how good is that!
kmawic
