door trims
door trims
after a set of matching door trims FB or EK, or i have a pair of red and white FB rears so a pair of red and white fronts
thanks
thanks
Re: door trims
Reckon I can help you out there Mick , if you can't find anything closer. Have a pretty nice set of red and white FB trims here.
Re: door trims
ok thanks, i'll give it a little longer but i'm interested had posts on facebook pages for ages with no luckBlacky wrote: Tue Nov 19, 2024 10:56 pm Reckon I can help you out there Mick , if you can't find anything closer. Have a pretty nice set of red and white FB trims here.
Re: door trims
Blacky would you have a rear left bumper corner in reasonable condition at all
thanks
thanks
Re: door trims
Hi Mick
Did see these on bookface if any good?
- IMG_4449.jpeg (509.42 KiB) Viewed 18078 times
Re: door trims
I dont have any left that aren't dinged mate, like an idiot I gave away or sold all my good bumpers, don't even have a decent set for the 2 door OR the trailerMick wrote: Thu Nov 21, 2024 8:42 pm Blacky would you have a rear left bumper corner in reasonable condition at all
thanks
Re: door trims
G'day Mick,
The photo below is my stash of red and silver trim. They are all in various stages of stuffed-ness, but you are welcome to any of it that helps. It was cleaned maybe 15 years ago with Kenko Shift-It and a nail brush (a tip from Steve Jackson), then ArmourAll'd. The black stuff will come off - it is the sealer/padding from the Special front armrests that tends to drip out over time.
How desperate are you for a bumper corner? I've probably got one, but it will most likely be daily driver condition (probably straight, probably no pimples, but chrome likely scuffed). If that condition suits, I'll see what I have (if it doesn't suit though I'm trying to avoid the hour or so of pulling stuff out to get to them).
Re: door trims
i've seen some adds from that fella but don't think i saw that add but he does have a front and rear right door trim on gumtree
Harv, i wasn't particularly after red i just have 2 good FB rear red/white trims (actually i don't really want red as the car will be black and i'm not a fan of that combination but if that's all i can get it's what i'll have to use) as for bumper corner not after anything near perfect just something that isn't painted silver or black
Re: door trims
I’ve got a left rear bumper end. Chrome is not perfect, and it has a scratch on the lower side where my finger is. Have not cleaned it at all. Let me know if you need it and Santa will get it into the mail. Would like to keep the bracket and overrider unless you need them too.
Re: door trims
thanks Harv that should be fine, i think i'm right for the bracket (actually pretty sure i'm right) and definitely don't need the overrider, i'll be passing through Sydney probably on Thursday 12/12 but will probably be lateish at night so could potentially pick it up
Re: door trims
No problem. Will separate out the bumper end. If I’m not home, or am asleep I’ll leave it on the front verandah. Will PM some contact info.
Re: door trims
Harv wrote: Sun Nov 24, 2024 6:26 am No problem. Will separate out the bumper end. If I’m not home, or am asleep I’ll leave it on the front verandah. Will PM some contact info.
Re: door trims
Thanks Harv, now i just have to wait for the 378% humidity to fark off in this sh!thole of a place so i feel like going out and doing stuffHarv wrote: Sun Nov 24, 2024 6:26 am No problem. Will separate out the bumper end. If I’m not home, or am asleep I’ll leave it on the front verandah. Will PM some contact info.
Re: door trims
Isn't Coffs Harbour meant to have the most temperate climate in Australia ????Mick wrote: Tue Dec 17, 2024 9:46 pm
Thanks Harv, now i just have to wait for the 378% humidity to fark off in this sh!thole of a place so i feel like going out and doing stuff![]()
Re: door trims
temperature is kinda stable rarely gets much under 20 and hot is mid 30s but humidity is insane, i was putting dynamat in the other day a really strenuous job
