3 Speed Rebuild
Posted: Sat Jan 23, 2010 11:49 pm
We have had to pull the gearbox out of Amandas car as the clutch is buggered. On inspection of the box i could only drain 50ml of fluid out of it as the front oil seal in it is stuffed.
I had a go at pulling it apart today but couldn't get past the pin that holds the cluster gears in position. I have removed the little welsh plugs and tried to access the cluster that way but still no joy.
Any help or diagrams / how to's would be great as we dont have a workshop manual yet.
We may end up replacing the box but arn't having much luck finding one ( we have 1 lead ) in good condition. ALSO should there be a return spring mounted on the clutch fork? As it has the hole there for a spring but the car didn't have one. Just the one that pushes up against the side plates / box.
Josh
Josh
