15" Volvo Steelies
15" Volvo Steelies
Apparently they will fit!
if anybody has some il grab em!
Be aware that while they will bolt on,the shape of the pressing in the center of the rim will not always allow the rim to fit against some brake set ups correctly.
The center of the rim ,depending on model,does not sit flat against the disc,and can only be pulled in tight by warping and slightly deflecting the center of the rim when the nuts are done up tight.
Check them on the car before buying.
J, If you want to run the early '47 caddy caps, They won't fit on volvo rims!
You are much better of having 15" outers mated to early centres and make sure you make them wide enough for the dish of the caddy caps, Next problem will be how low can you get with widened rims?
Cheers Theo Z........................
FB/EK Car Club of QLD.
