Grey Motor/Trimatic Diff Ratio
Posted: Sun Jan 03, 2010 11:00 am
by ek61
this has prob been discussed b4 but :D :D
grey motor trimatic what diff ratio would you use
i had a 3:55 ratio in there with the red motor and tri was good off the line but a bit revvy when cruising long distances
i have a 2:78 in there now that was great when we went to bendigo
but now that im running a grey motor reccon it would be a bit hard off the line
i have another 3:55 to put back in there but was thinking 3:36 might be a bit better
any thoughts
cheers dave
Posted: Sun Jan 03, 2010 11:43 am
by EKWagon
3.36 is perfect for all round driving, as you have said the 3.55 is great off the line but revs high, 3.08 is a little sluggish.
EKWagon
Posted: Sun Jan 03, 2010 11:45 am
by Stygian
With the Norman huffer on the grey, I reckon it would have the torque to spin a 3.36 around town quite well.
When I was a broke postgrad, I put a 3.36 in my stock manual grey EK. Great out on the flat sections of highway, but not the hills, and sluggish off the mark around town. But it stopped the car from revving its ring out at 50mph, so I thought it was a good trade off.
I'm putting a warm grey in my car and have already installed a 3.55... may be a bit revvy on the highway, but it won't die in the arse on the hills and should be quick off the mark around town...
Posted: Sun Jan 03, 2010 2:54 pm
by FB MAD
Yep, stock grey would pull up with 3.36 as it's a good average between the extremes of 3.89 grey ratio and the other end with a 2.78.
3.08 would be OK I guess with a grey on the highway, but down a bit on pickup around town but there again you are going to run a Norman so it will be up somewhat in power so a 3.08 would still do alright with a Norman I reckon.
Even with a modified engine I think 2.78 would be a bit to tall for a grey.
I think?? from memory the LC/LJ Torana's running a 138 RED and trimatic used the 3.36 as standard fitment.LC/LJ's were only slightly lighter than an FB/EK believe it or not so are of a similar weight to compare.Although 138 RED's are a bit more HP output than a 138 grey.
My vote is 3.36.
Posted: Sun Jan 03, 2010 5:02 pm
by vmx-mxr
I'm planning on running a slippery 3.36 in the ute - seems like the best of both worlds
Dave Mac :D
Posted: Sun Jan 03, 2010 5:32 pm
by Trev
I have a 3.36
Posted: Sun Jan 03, 2010 7:59 pm
by Devilrod
I've got a red 161-trimatic-3:36 combo-14"wheels. Perfect alrounder.
Posted: Sun Jan 03, 2010 10:13 pm
by ek61
cheers 4 the advice 8) 8)
3:36 it is then
ill put the 3:55 back under the bench :lol:
cheers again dave
