4 speed to auto
FantaC
4 speed to auto
Post by FantaC »
Was thinking about putting a trimatic auto into my EH
it has an all Aussie 4 speed at the moment so will the auto fit ?
will i have to change the tail shaft ?
crossmember too ?
im only driving a EH till i get a FB-EK :)
Cheers John
Yep , piece a cake mate, just need the right auto (shifter on the right hand side) and its virtually a bolt in job. I have quite a few of the bits you will need - will talk tomorrow.
FB MAD
Post by FB MAD »
Remember reading a fair bit on conversions on an EJ/EH forum a while back ??
Google EJ/EH forum or similar keywords and it might come up??
FB MAD
Post by FB MAD »
Maybe something in here for you?? :arrow: http://forum.ejehclubqld.com/ehclub/forum/
FB MAD
Post by FB MAD »
FantaC
Post by FantaC »
thanks guy`s
8)
Post by mrs ratbox »
like blacky said all you need is the actual parts associated with the auto ie box, converter, flexplate, bolts, shift. crossmember, tailshaft identical
FantaC
Post by FantaC »
Thanks RatBox
have everything but a shifter even have an auto radiator but might get a seperate oil cooler
Spewing cos i replaced the steering colum with an auto colum but i cut the gear lever of and gutted it , so will just settle for a T bar type
or could i fit a manual gear selecter with the auto colum setup ?
Don't forget to remove the spigot bearing either...
FantaC
Post by FantaC »
thanks DevilRod
Sammy
Post by Sammy »
Devilrod wrote:Don't forget to remove the spigot bearing either...
and put the auto spigot in there!
Regards,
Sammy.
http://www.oldholdens.com
FantaC
Post by FantaC »
Thanks Sammy
