Ignition timimg marks
Posted: Wed Sep 09, 2009 9:29 pm
by hammondo
I was going to put some marks on the balancer of the grey motor while I have it at TDC. whats the best spot for future tuning? 10 degrees before TDC?
Posted: Sat Sep 12, 2009 8:04 am
by FB MAD
If you are having trouble seeing the steel ball on the flywheel with the timing light dab some white paint on it.
If you want some timing advance move the steel ball until you can just see it on the left of the timing aperture, that will probaly give it about 4 or 5 degrees more advance timing than standard but like Tim said, too much advance and it will ping under load.
Use premium fuel and there will be less chance of pinging.
Posted: Sat Sep 12, 2009 8:50 pm
by hammondo
cheers guys,I didn'tknowabout the steel ball :oops:
I endedup puttingmarks on the pully at TDC and 10deg BTDC so I should be able to do itboth ways.
