Moderators: reidy , Blacky
mudgroup
Posts: 314 Joined: Thu Mar 19, 2009 5:01 pm
Post
by mudgroup » Thu Aug 27, 2009 10:03 am
any tricks to removing a gearbox from a 138 grey ?
all visible bolts removed... and has moved about 10mm from engine.. but doesn't want to budge
Posts: 14246 Joined: Tue Jul 20, 2004 8:58 am
Post
by Blacky » Thu Aug 27, 2009 2:05 pm
mudgroup
Post
by mudgroup » Thu Aug 27, 2009 2:08 pm
mmm.. always one.... yes !
Post
by Blacky » Thu Aug 27, 2009 2:15 pm
O.K. - thats a good start
more info please , is the gearbox off the dowels in the back of the block??
does it rotate on the input shaft ?
Another no brainer - is the starter motor removed ?
mudgroup
Post
by mudgroup » Thu Aug 27, 2009 2:17 pm
yes.. dowels clear... rotates... and starter removed !
Post
by Blacky » Thu Aug 27, 2009 2:22 pm
hmmmmm , how hard have you tried reefing on it ? If its been in there for years maybe there is a groove or something worn in the spigot bush that is catching
No brainer #3 - dust cover off ?
mudgroup
Post
by mudgroup » Thu Aug 27, 2009 2:26 pm
one thing i have learnt when playing with these cars.. not to put all 140kgs behind it !
dust cover... ?
Post
by Blacky » Thu Aug 27, 2009 2:32 pm
The flywheel dust cover that sits under the sump and in front of the flywheel - if its still on there you will have to pull REALLY hard to get the 'box out.
mudgroup
Post
by mudgroup » Thu Aug 27, 2009 2:38 pm
righto... will have another go tonight.. thanks !
mudgroup
Post
by mudgroup » Fri Aug 28, 2009 7:16 am
blacky, removed dust cover and it slid off nice and gently... thanks!
Post
by Blacky » Fri Aug 28, 2009 9:20 am
No worries , all part of the service
