186 timing
Posted: Sun Aug 23, 2009 6:11 pm
by Trev
Just put a second hand 186 in my HK and I have had trouble setting up the timing
First I found TDC (white dot on zero and checked with a screw driver that the piston was at the top) and put the dizzy in pointing at number 1 lead, tried to start and it coughed and spluttered, so I turned the dizzy a bit and tried it again and it ran enough for me to tune it by ear then checked with a timing light and the little white dot on the balancer was about 1/8th of a turn out, but this is were the engine runs the best
Help! Trev
Posted: Sun Aug 23, 2009 6:30 pm
Maybe the outer has turned on the inner Trev , pretty common with red motors.
Posted: Sun Aug 23, 2009 6:42 pm
by Trev
Thats why I checked with the screw driver in the number 1 spark plug hole
, Trev
Posted: Sun Aug 23, 2009 8:29 pm
by Devilrod
Posted: Mon Aug 24, 2009 4:01 am
by Trev
Pretty much what I've done, it just shits me that when it is all lined up it runs like crap
, Trev
Posted: Mon Aug 24, 2009 4:02 am
by Trev
Terry (FBMAD) rang me last night for a chin wag and gave me a few things to go on with, I'll try again when I get home from work
, thanks mate, Trev.
Posted: Mon Aug 24, 2009 2:36 pm
by rosco
Sorry Trev,
just found this - relax - no novel for you...... and no cigar for me......
What I did with mine once I found where the ignition was best set ....
was to scribe a line with a ruler and diamond-tip cutter from the centre of the balancer out to the circumference... no great trench, but a line which could be found with a timing light.......
This way, if ever the outer belt pulley moved on the central hub - it would "show up" by the lines not matching.
It also avoided the necessity of having to "find" the spot again - just re-scribe the pulley from the hub........ but, mine hasn't slipped yet.......
Again - sorry, Trev - better late than never....
Posted: Mon Aug 24, 2009 7:21 pm
by Trev
Good idea Rosco
Had a play with it today and this is what I found.
First I changed the dizzy for one that I had with a 10 deg BTDC sticker on it, I believe it was for a hotted up motor, which I thought would suit this one it has a Yella Terra head and a bit of a cam (not sure about the cam numbers?).
Ran heaps better with this one, got my timing light onto it and found it didn't work on number 1 lead so I checked it on number 2 lead and it flashed, checked the rest and it flashed on 3 and 4 leads but not on 5 and 6, got it going on number 1 but still no go on 5 and 6, so, I'm thinking there is something afoot at the circle K
, Trev
Posted: Tue Aug 25, 2009 1:56 pm
by rosco
I'm not up to speed (excuse pun) with hot motors Trev - I have never owned or maintained one so can't give you any input.
I am expecting your timing light to be a "battery" type... that is, it has three leads?.... one each for battery pos and neg and another to connect to the plug.
I have found that some spark plug leads do not lend themselves readily to connecting timing lights to - this may be the issue with not getting a "flash" from your light........
You state that the motor is running much better - and I would take this as meaning that all cylinders are firing - even though you can't get a flash on three of them from the timing light.......?
An old trick we used to employ with timing lights (especially those terrible neon ones) to get a sound "pulse" - was to fit a spring over the plug and into the plug lead - this need be long enough so that the alligator clip of the timing light input could also fit on the spring whilst it was in place......
Failing this - I would suspect you have carbon leads and the "message" is just not getting conveyed through them.......
Let me know if you need more....
Posted: Tue Aug 25, 2009 5:17 pm
by Trev
I have just replaced leads, rotor button, plugs and dizzy cap, so it will get it's maiden trip to work tomorrow
, Trev
Posted: Wed Aug 26, 2009 2:04 pm
by rosco
And.......?
