Just started to get motivated to work on my cars again have acquired another ek ute .Local show is at the end of august was thinking about getting it ready for the driving events might stick this in the front
just wondering if it would be worth the effort just to go and do some skids.Have a spare t400 for the gearbox spare hr front crossmember with rear mounted rack heaps of hr diffs (will need them)Whats your opinions
regards fat
Just got back from working on the cars started stripping the moss wagon of its front sheetmetal for the ute.got the passenger side dogleg fixed just got to finish around the bottom of the door
regards fat
ps pics later tonight
we heard that in july for the end of august
come on you can do it but depends on what yor doing if yor going for the full shinney paint thing like the other could be a push, if you've got all the stuff basically ready to go and a better work ethic than me you should be right
TIP: this is not the time of year to be doing deadline type jobs spose it's a little better on the coast
yep will be shiny paint but with more wow then the last ute.have nearly all the parts at my disposal .Ute will be going to the blasters on monday tuesday so will see what else evolves .Just got the fuel tank out Was a make shift job held in with self tappers and some gal flat strap and some bits of angle iron.Going to put one of my injected 5 litres in this one as ive bought another fe ute with chassis rails in it ( big project) turbo 700 hq stubs and rear mounted rackand pinion diff will probably be hr as ive got a few of them underside as ive got a commodore diff already cut down (fc Ute)
should be fun to work to a date
regards fatboy
