offset for 15in mags
Posted: Mon Jun 15, 2009 5:37 pm
by J
im fitting american racing torque thrusts to the ek.
I have a standard front end (kingpin) with torana disc brakes on it.
I also have an HR diff.
what kinda offset would fit alright, and does anybody know the offset of 13x6 cheviot hustlers?
Posted: Mon Jun 15, 2009 8:12 pm
by mrs ratbox
can you get torque thrusts in early holden pattern
sorry but i doubt you'll get the right offset
Posted: Mon Jun 15, 2009 8:27 pm
by J
american racing do custom offset and custom stud patterns
Posted: Mon Jun 15, 2009 9:06 pm
by Trev
Don't know about the standard front end but HR disc front I always ask for the "HR disc front off set" , Trev
Posted: Mon Jun 15, 2009 10:22 pm
by Devilrod
J measure the backspace on the rims you took off the car at least its a start, then go from there.
Or place a straight edge (long steel rule or level) on the face of the drum where your rims sit, then measure out to the gaurd lip and back to the steering arms from the ege of the straight edge touching the drum. This should be more than enough to work out backspacing and clearance to the gaurd. You may have to make a few measurements around the gaurd to get a minimum cleareance. Sorry no pics to help.
Posted: Mon Jun 15, 2009 10:54 pm
by oldnek
J, you can download a backspace chart from the Rocket industries site, in their wheel section. It shows exactly where you have to measure to get all your specs for wheel measurements.
John
Posted: Mon Jun 15, 2009 11:10 pm
by Finny
When I was looking for wheels to suit my car, I was under the impression that HR Disc and HR drum wheels were different.
I even had a photo, the hole was supposedly only on Disc brake wheels.
However after reading through the HR Workshop manual, it says that the HR only has ONE type of wheels for all models and types.
Also I thought that FB/EK and HR wheels could be swapped without issue on drum brake models ?
The wheels specs are the same in the EK Workshop manual.
Now I'm a bit confused.
Posted: Tue Jun 16, 2009 2:01 pm
by mrs ratbox
the HR "discbrake" wheels are different as in pic, also don't know why but i put FB/EK wheels on a HR rear on the moss car and the wheels locked up HR disc rims no problem
i was always lead to believe the rims were different but never had the problem before
Posted: Tue Jun 16, 2009 2:03 pm
by mrs ratbox
J wrote:american racing do custom offset and custom stud patterns
on the torque thrusts, they never used to but that's a few years back now
Posted: Tue Jun 16, 2009 8:02 pm
by oldnek
Drums brake rims were in fact different, where the 4 slots are folded in the centre of the rim and facing rearward of the rim, the drum brake versions were squared off and protruded toward the centre slightly. This is the area of the rim that makes contact with the caliper. Whilst the disc brake rims were cut or pressed curved so there was no protrusion.
Posted: Tue Jun 16, 2009 8:49 pm
by J
ratbox wrote:on the torque thrusts, they never used to but that's a few years back now
Thats exactly what I am getting, still do it I called the bloke the other day.
Posted: Sun Jun 28, 2009 10:32 pm
by J
I just found this. Posting it up here for anybody who wants to order wheels in the future.
http://www.americanracing.com.au/shop/i ... =page&id=2
Posted: Tue Jun 30, 2009 1:19 am
by fastjbav6
Hi J,
Just drive the EK to the Tyre/Mag shop and get them to do the measurements so they can supply the correct off set.
So does this mean I get my wheel nuts back soon?(and a set of Dragways for the FB Standard)
Seb
Posted: Mon Jul 06, 2009 6:45 pm
by vintageholden
i have 15" dragways on my ute,and its standard all around
