Torona calipers on "HR" stubs????
Posted: Wed May 27, 2009 11:41 pm
by dave68
O.k. I have heard that "UC" cals will fit on "HR" stubs with "UC" rotars, my question to those that know more than I is, what other torana calipers fit as well with there respective rotars with no major mods involved useing "HR" stubs....:?:
All answers accepted with glee.. :lol: ... :wink: :wink: :wink:
Posted: Thu May 28, 2009 12:46 pm
by Sammy
i didn't know any fitted with the HR stubs but i know a LH stub and caliper/disk will fit on no worries, used to have these on my EK Wagon with HR front end .... only thing you need to do is get them shimmed up a bit to get the camber back to where it should be.
Posted: Thu May 28, 2009 2:36 pm
by mrs ratbox
my V8 EK ute had HR stubs with HR rotors and LH callipers, as far as i know all 13" callipers bolt on, only thing with the setup i had is maybe the LH/LX/UC rotors are thicker than HR which might be a drama when pads wear i never had a problem
Posted: Thu May 28, 2009 7:27 pm
by FB MAD
I've got some LH/LX/UC discs here at home so will measure the thickness of the braking area of the rotor and let you know the thickness but from memory they are a bit thicker than the HR discs??
Posted: Thu May 28, 2009 10:24 pm
by dave68
I was told by the guy that mechined my "HR" slotted X drilled rotars that they have to be 9 or 12mm ( can't remember ) but mine are at the end of there life, no more machin' for those suckers. That is why the intrest in the torana stuff.... :wink: :wink:
Posted: Thu May 28, 2009 10:49 pm
by mrs ratbox
rememder the torana rotors will move yor wheels out not sure how much i think 1/2" or so
Posted: Fri May 29, 2009 3:17 pm
by Sammy
hr front discs are as follows:
253mm diameter
9.7mm thick on the pad area
50mm from back of disc to wheel mounting face
9mm minimum thickness
LH/LX/UC front dics:
256mm diameter
16mm thick on the pad area
77mm from back of disc to wheel mounting face
14.3mm minimum thickness 9mm
Posted: Mon Jun 15, 2009 9:30 pm
by ek61
i have uc torana rotors and callipers using hr stubs on my ek no probs at all with them 8) 8)
Posted: Mon Jun 15, 2009 10:23 pm
by Devilrod
Think I've got LH on mine, I've forgotten. But I know they're LH or LX.
Posted: Tue Jun 16, 2009 8:05 am
by dave68
Thanks all, have found a new set so will see if they are Girloc or PBA?...
