Roof section please
Posted: Fri May 22, 2009 7:29 pm
by Harko
Hi all , Im after a roof or a good left half of a sedan roof , Sydney to Batemans bay prefered
Posted: Sat May 23, 2009 4:05 pm
by fatfbwagon
i will have a look at the shell ive got here and let you know. im on central coast but. cheers wayne
Posted: Sat May 23, 2009 4:47 pm
by Harko
Thanks wayne , sounds good .
Posted: Sat May 23, 2009 5:01 pm
by fatfbwagon
hi i just had a look . depending on how much roof you need depends on how good it is for you. it has a couple of fist size dents in it but not too bad to fix. the front pillars are ok on the upright section but the bottom horizontal parts are rusted. the centre pillars are good and solid. and the rear pillars are ok on the inside. the drip rails have rusted off on the outside but they still seem pretty solid i guess. the centre section of at the top of the rear window is rusted out .the channel inside the car above the rear windscreen is rusted out too. but seems to be mostly on the right side of the car. im gonna take some pics so if you like send me your email address and ill send them to you thanks wayne
Posted: Sat May 23, 2009 5:44 pm
by Harko
Wow , probably need a clean one ... Sounds like the good section on that is the only area I dont need ..
Thanks for the reply though , much apreciated
Posted: Wed May 27, 2009 6:09 pm
by Harko
Just to add , I dont mind cutting the roof off myself ofcourse
Posted: Thu May 28, 2009 4:26 pm
by minifb
I can get one here....Its in between syd and the bay VIA a little detour.....
Posted: Thu May 28, 2009 6:06 pm
by Harko
Sounds good , Ill see if I can blow up another corolla on pick up :)
Posted: Sat May 30, 2009 1:29 pm
by Harko
Are there any others around that someone may know of ?
Posted: Tue Jun 09, 2009 7:40 pm
by Harko
anyone ? anything !
Posted: Wed Jun 10, 2009 10:21 pm
by southcoastkustom
One good one in Adelaide if ya want it Mark. You cut it and anything else you want off the shell urs for nics! 8)
